Restoring 1991 Acura Integra
I have this Acura i bought and I've managed to seek all the problems out except a minor problem with a sound coming from the throttle body when i turn it off. Also it revs up and down when I first turn it on....
any ideas or suggestion?
i know it s hard to run diagnosis through just some words... i know I'm a kinetic learner myself
never thought that was it. so should i detach what, to leak out the coolant last time i did it it was by accident. I just removed the hose from the radiator to the block to put sealant and it all fell out HA
wow i didnt see you replied then LOL...um yeah the manual will tell you what to do. but if you cant find it, there is a drain **** on the bottom of the radiator. open that and the radiator cap and it will pour out. then there is a bleeder valve for when you put the coolant back in. you need to bleed the air out. PM me if you need help. i'm not sure the manual covers that or not
wreckedmyteg
Jul 15, 2005 06:00 AM
Thagreybomber
Jul 10, 2002 07:40 AM
