BEST N/A EXHAUST?
Old May 8, 2010 | 06:01 PM
teg_racer's Avatar
Default BEST N/A EXHAUST?
ive checked around online and listened to a **** ton of exhausts.. i hate them all.
i have a sleeved 85mm gsr block 12.5:1 compression and a fully ported head with skunk pro 2 cams. im currently running a standard skunk2 megapower exhaust (60mm) sounds perfect but its to restricting..
ive listened to all the buddy club exhausts and all the skunk2 exhausts between 70mm and 76mm.. they make lots of power but sound like a damn rice rocket,
what is the best sounding and performing exhaust i can get my hands on?
im going to start looking into T1R
if you have anything non restrictive and has a good low tone let me know or post a clip. thanks guys
Old May 8, 2010 | 06:40 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: BEST N/A EXHAUST?
T1R is good, Thermal is good too. Most people build a custom exhaust at the level your car is at to get the sound they want using various length resonators and type of mufflers as well as cats.
Old May 8, 2010 | 07:03 PM
teg_racer's Avatar
yea.. just sucks cause there is no shops around here so im stuck cutting welding and wasting money haha. i dunno whether i should get 70mm or what.. checked out the t1r. they were a little more expensive then i though. 1000 bucks is a little to pricey haha
Old May 8, 2010 | 07:09 PM
teg_racer's Avatar
ive never heard of thermal but i looked em up. they sound pretty nice. any idea on how they flow? dyno testing and all that
Old May 8, 2010 | 08:10 PM
96redEKhatch's Avatar
T1R is sex to your ears though!!!!
Old May 8, 2010 | 08:17 PM
teg_racer's Avatar
yea. i kick myself in the *** for letting one slip through my hands last year haha. had it for 2 days and sold it before i installed cause i got twice what i paid. now im running a mega power, wish i could find some more vids of a thermal exhaust on an na car..
Old May 9, 2010 | 07:21 AM
killerpenguin21's Avatar
kteller 3 inch piping, vibrant resonator and muffler
Old May 9, 2010 | 08:46 AM
teg_racer's Avatar
kinda a dumb question.. but i found a thermal exhaust for hella cheap but its for a civic.. are then bends different for a 99-00 civic or just length? cause cutting i dont mind. i would have to anyhow cause im running a race header. long tube
Old May 9, 2010 | 08:53 AM
hondamn1320's Avatar
If it's off a hatch, the axle back will need to be extended (if your car is a coupe).
Old May 9, 2010 | 09:07 AM
teg_racer's Avatar
so thats it? i just want to make sure i can make all the bends line up.. guys givin a hella good deal, yes mine is a 2dr teg, so 200 bucks.. i should jump on that right? haha
Old May 9, 2010 | 09:38 AM
OH_1fstgsr's Avatar
That's what I was going to say. Find a good shop to do the work.
I have 2.5" Vibrant muffler on my GSR with no resonator a bit loud but still nice. I will be adding a resonator soon. All custom 2.5" stainless.
Old May 9, 2010 | 10:15 AM
bizzerk89's Avatar
whats the biggest catback a stock cat will bolt too.. plan on a swap and dont want to buy the header and test pipe right now if i dont have to
Old May 9, 2010 | 10:23 AM
TheShodan's Avatar
Moderator
Even at that compression, 3" is a little overkill. he does need a little backrpressure. It will hurt his midrange a bit
Old May 9, 2010 | 10:42 AM
teg_racer's Avatar
so i should look around 70mm or like a 2.75.. i dunno if the 2.5 will be to restrictive.. its what i have now. maybe its just restrictive because thats how it was made. dropped the header while tuning and made about 12whp..
Old May 9, 2010 | 11:45 AM
would depend on the size of the main tube on the header and the collector. if that collector is 2.5 then 3 inch is a no brainer because anything after that collector/megaphone is a restriction.
there have been no dynos of people losing power from a 3 inch catback.
Old May 9, 2010 | 11:48 AM
B20vEf9's Avatar
What is back pressure..? Cars don't need back pressure.
Old May 9, 2010 | 11:49 AM
B20vEf9's Avatar
This
Old May 9, 2010 | 12:13 PM
teg_racer's Avatar
im running a profab long tube header i believe those are 2.5 inch
Old May 9, 2010 | 12:24 PM
the backpressure you need also depends on how good your header can scavenge i believe.
Old May 9, 2010 | 02:19 PM
DDTECH's Avatar
Backpressure is need if you care about gas mileage.
Honestly people who still don't understand velocity flow need to be quiet.
Old May 9, 2010 | 02:29 PM
SR20S13's Avatar
yeah 3inch makes more power, its also louder so it depends on what you want
make the most power
or have a quieter exhaust
your choice
Old May 9, 2010 | 02:45 PM
teg_racer's Avatar
damn... i think that thermal R&D CL type at a 2.5 would be good... better than the one i have anyhow
Old May 9, 2010 | 02:56 PM
00Red_SiR's Avatar
All Motor Mentor
The stock cat is probably the most restrictive part of the exhaust. If you remove the cat and measure the inlet/outlet, you'll be shocked to notice that it's less than 2" (inches). Installing a large cat back will do nothing for your without addressing that restriction first.
Old May 9, 2010 | 04:36 PM
teg_racer's Avatar
goes from the header to a greddy cat then the exhaust both are 2.5
Old May 9, 2010 | 10:00 PM
jv88_dc2's Avatar
why not keep your exhaust now and get an electric cutout? that way you can still keep the nice sound of your current exhaust and open up your cutout and get more power when you want to. just a suggestion
