NO VTEC jdm motor jdm ecu look
so i got a 97 coupe with a jdm b18c swap using the y8 harness with a jdm p72 obd2a ecu skunk2 stage one cams with sk2 cam gears and a sk2 manifold and a bbk throttle body
at first i thought i wasent getting vtec because my speedo wasent working but know it working and no vtec car runs great but no vtec
i dont want to convert to usdm specs only cel im getting is for o2 and yes it a jdm ecu
fyi -- i know that the previous owner thought it was a usdm ecu so he did the jumper to bypass the cps"jdm motors dont have a cps" maybe that my problem that it wired to bypass the cps "when the ecu is not looking for it "or it on the wrong ecu ,should i wire it to stock and try that
here my ecu just so people can confirm it a jdm ecu
can anyone tell me excactly what the motor needs to vtec to work this is what i know so far
speedo needs to work
oil level is good
knock sensor needs to be hooked up
vtec soilenod connected
vtec oil pressure switch "only on usdm motors-ecu" connected
is their any more step to take to get vtec to engage
oil level is good
O2 will stop vtec i have same issue ATM
buddy's jdm GSR did same thing
u also need secondary throttle body's working
and i think u need the vss working also
meheartmycivic
Aug 17, 2009 08:39 PM
