Is my head gasket leaking? (Pic inside)
Old May 8, 2010 | 01:50 PM
koss1229's Avatar
Default Is my head gasket leaking? (Pic inside)
Wanna make sure if this is a head gasket leak? Engine oil disappears alone with coolant, but not mixing together. Also, there is no smoke from the exhaust at all. Just took the flywheel cover to check if theres any leak from the main seal - all dry and clean.
So, this is the only fresh-oil spot i found
Old May 8, 2010 | 02:08 PM
grjr's Avatar
Default Re: Is my head gasket leaking? (Pic inside)
did you check around the valve cover and cam seal? could be running down tge side of the head and pooling there
Old May 8, 2010 | 02:17 PM
koss1229's Avatar
Yeah, everything seems to be clean and dry. Even Vtec solenoid gasket. Im losing a qt of oil every 250-300 miles and the same amount of coolant, i think. You can see, there is oil under the header. I can smell burning oil while driving with open roof too. Im tired of this crazy oil consumption
Old May 8, 2010 | 06:04 PM
eeeeee!'s Avatar
i had that too. a k or so miles later after i first noticed it, i had to make plans to pull the motor. find out what it is quick! lol
in my case, i didnt do anything about it. later on my pistons/rings are blown. 115k miles, 01 gsr
Old May 9, 2010 | 08:59 AM
LS/VTEC TURBO's Avatar
it looks like the same thing i had on my car.take out your distributor change the o-ring and your good to go.
Old May 9, 2010 | 06:26 PM
92 CiviC H.B's Avatar
i have the same problem.
Old May 9, 2010 | 09:53 PM
SkidmarkEH2's Avatar
clean it with brake cleaner and drive it around the block. then see where the oil is coming from. most likely the cam seal
Old May 9, 2010 | 09:57 PM
jdm_bones's Avatar
Coolent and oil lose a good sign of a blown head gasket, but like already mentioned clean with brake cleaner then take it for a spin and check, do a compression check...Most of the time it's a bad cam seal, or the O ring around dizzy.
Old May 10, 2010 | 04:07 PM
Domnificent's Avatar
**** yea!! thanks ive also been having this issue!! I gotta get myself a new O-ring!!
Old May 11, 2010 | 05:37 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
If you're losing coolant along with oil then yeah it's gotta be a blown head gasket. Any white smoke out the tail pipe?
I had oil in the same area, replaced cam end plug, VTEC switch housing gasket, and distributor o-ring, and none of those fixed it. Later I replaced the smaller gasket on the actual VTEC solenoid (the little round housing, gasket was original at 280K+ miles) and that fixed it right up.
But with your coolant loss I would be more suspicious of the blown head gasket.
gooblinn258
Feb 12, 2014 04:51 AM
n20delslow
22
Oct 31, 2011 10:25 AM
dc2_dude
Feb 13, 2009 12:12 AM
spender1326
Jun 24, 2005 06:41 PM
PatrickGSR94
Mar 5, 2003 10:02 PM
