b18b1 help!
Old May 8, 2010 | 11:49 AM
viejohombre's Avatar
Default b18b1 help!
I have 97 civic with a D16Y5 and i want to swap it with a B18B1, i need info on what type of motor mount i will need and which wiring harness. I have the ecu for the B18B1 and the engines wiring just need to find out which harness will fit between ecu and engines wiring. I also want to know if im going to have to change transmissions
help please!
Old May 8, 2010 | 01:19 PM
hondamn1320's Avatar
Default Re: b18b1 help!
SI rear "T" bracket, SI motor post mount, SI a/c bracket*, SI lower transmission bracket*, SI starter, SI shift linkage*, SI axles*.
*: can be off any b-series equipped vehicle
You'll also need a b-series transmission.
Your wiring harness should work.
Old May 30, 2010 | 09:56 AM
so any b series starter wont work? cause i have the b18b1 starter already, can i just use that one?
slopoke1989
22
Jul 23, 2009 08:53 PM
white_crx_guy
Texas -OK -LA (Sales)
Dec 19, 2008 04:35 AM
98boostedy8
Dec 2, 2008 07:41 PM
90civicB16
Oct 9, 2003 12:18 PM
