Teggy spoiler removal
hey,
i know this has been repeated across various threads, however i was wondering if anyone has some helpful links or tips as to removing the black cover,that covers the electronics to the spoiler lights? for those of us whom of which has GSR's and wish to remove our spoilers?
thanks
thanks
Teggy, consider this a warning. The ITR forum is for ITR-specific topics. A non-ITR wing/spoiler modification does not belong here. There is a non-R Integra forum that you should direct these questions to. You also should learn how to search, as I'm sure the "helpful links and tips" will be found there. I already posted those directions in your previous thread.
*MOVED*
*MOVED*
hey,
thanks
thanks
There are four 10mm nuts that hold on the spoiler, remove them.. The spoiler will be loose.. Then you will see wiring ran thru a hole underneath the spoiler.. Follow it.. There are four tabs on the third brake light.. push them in with a very small phillips head screw driver and remove the connector and plug in your connector for the third brake light.
Try searching.
