Another D16Z6 VTEC question - wiring
Old May 8, 2010 | 07:32 AM
TxFireman1972's Avatar
Default Another D16Z6 VTEC question - wiring
Another question on the swap....
The D16Z6 I'm buying to put in my 95 DX comes with the engine wiring harness and I will be picking up a P28 ECU. Will I still have to wire the VTEC? The engine harness will of course have the harness that hooks up the VTEC itself. But will I still have to wire it in somewhere, or is there another harness I can buy to make it just like factory? I know its not hard to wire, just wondered if there is a plug and play option. Thanks
Old May 9, 2010 | 05:23 PM
Default Re: Another D16Z6 VTEC question - wiring
Anyone?
Old May 9, 2010 | 05:33 PM
turbostd's Avatar
nope you have to run the wire from the ecu to the shock tower plug.
Old May 9, 2010 | 05:39 PM
ok, thats what I thought. Thanks for the help.
Old May 20, 2010 | 06:19 AM
farfrumugen's Avatar
hijack....i just picked up a 94 dx coupe yesterday and my buddy is giving me his sohc vtec out of his sol. what wires need to be ran from ecu to shocktower mount? i was reading through the faq's and the pics are not showing in the vtec wiring thread, i found this thread by doing a search.
i know this sounds stupid but where do you get the actual pins to plug into the ecu and /or plugs? do old pins just pop out with a special tool if i want to salvage them.
thanks for any replies.
adam
Old May 24, 2010 | 05:00 PM
I picked up some ECU plugs and removed the pins to use on the ECU end of my wires. My question is, how do I wire in to the shock tower plug? Do I need to find a scrap shock tower plug (car side) and remove the pins, just like I did on the ECU end? Also, can anyone show me which spots to put the new pins in?
Old May 24, 2010 | 05:12 PM
egsleepercivic's Avatar
thats how I did mine for the knock sensor on my B16a, IMO its the cleanest way
Old May 24, 2010 | 05:14 PM
Anybody happen to have any extra shock tower plugs laying around?
Old May 24, 2010 | 05:24 PM
Also, is there anything special to do to add the pins to the shock tower plug?
Old May 24, 2010 | 05:27 PM
HondaPartsHero's Avatar
Technical Hero
the pins should be any OBD0/1 female or male (I can't remember which on that side). Just insert the pins its pretty easy.
Old May 24, 2010 | 05:32 PM
Putting pins in is the easy part...what about removing them? lol
Old May 24, 2010 | 05:47 PM
Technical Hero
If there is something in that port its really easy. Look inside the plug and push up on the tab with a small screwdriver or pin and pull the wire out.
If male first:
then
if female
Old May 24, 2010 | 05:57 PM
mine is round like the first pic you posted:
Old May 24, 2010 | 06:29 PM
Mine looks like this one on the front of the plug:
And looks like this on the back side of the plug:
Old May 24, 2010 | 06:47 PM
D16SiHatch's Avatar
that's because your car is not factory pre-wired for vtec. only the 92's were.
you need to take the 2 wires on the ex/si engine harness side and run them into the cabin.
Old May 24, 2010 | 06:57 PM
Oh yeah I knew that. But you can also wire them into the blank spots on the existing shock tower plug on the car, then run wire from there to the ECU. That way it looks factory, and unplugs just like factory. These are the two empty slots on the vehicle harness, that mate up with the VTEC wires on the engine harness
Old May 24, 2010 | 07:03 PM
D16SiHatch's Avatar
But you can also wire them into the black spots on the existing shock tower plug on the car, then run wire from there to the ECU. That way it looks factory, and unplugs just like factory. These are the two empty slots on the vehicle harness, that mate up with the VTEC wires on the engine harness
i get it, i just didn't know if we were on the same page lol
Old May 24, 2010 | 07:07 PM
I dont know what page I'm on lately, this Honda stuff is a entirely new book for me LOL
Old May 24, 2010 | 07:09 PM
D16SiHatch's Avatar
haha, well we all have to start somewhere
Old May 24, 2010 | 07:21 PM
Sr420Det's Avatar
Ur doing better than 99% of them. keep up the good work
Old May 24, 2010 | 07:30 PM
D16SiHatch's Avatar
i have to concur. some people that come on here for help really have no business anywhere near the workings of a motor vehicle.
Old May 24, 2010 | 07:35 PM
87 SiviK Si's Avatar
That is true, Ive been following your threads on here and other boards and you are the perfect noob. You are asking the right questions, searching and taking the replies all in stride and without hesitation. You are where a lot of Honda guys want to be, your just steamrolling into swaps and all kinds of projects on your daily. Keep it up. Soon enough you;ll be getting rid of your rig for another econobox.
Old May 25, 2010 | 04:28 AM
Its funny you say that, because as I put this "project budget" together, I'm already wondering if I can find a nice clean coupe somewhere and do a full build, with full suspension, newer engine swap, wire tucks etc. LOL
Old May 25, 2010 | 07:24 AM
Technical Hero
By your pic u should just be able to plug the new pin in. If u need some pins let me know I have a ton extra
Old May 25, 2010 | 07:36 AM
are the shock tower pins and ecu pins different? They look a little different. If they are different and you have some extra shock tower pins, I definitely need a couple. Pm me and let me know how much. Thanks
