F/S ......... GARAGE SALE .. always updated ..
WTB...
EK coupe power door panels with covers..
dap 96-98 civic hood
Dap 96-98 civic passanger fender
FOR SALE ITEMS_____________________________________________ ______________
EG spec H&R race springs .... SOLD
EK spec Benen tie bar ...
$80 FIRM picked up in Blaine ..
small scrape at the bottom
EK spec COMPTECH 22mm rear sway bar and tie bar ..
SOLD
Koni yellow shocks and H&R race drop springs EG/DC spec
SOLD
GOLD ROTA BOOST wheels (advan rg2 replica)
16 inch
5 lug (ITR/ RSX.. etc)
falken tires
2 have good tires ..
2 need to be replaced
1 wheel has minor curb about 5-6 inch
1 other wheel has minor curb abuot 1 1/2 - 2 inch
$400 ... picked up in Blaine WA
2 tires look like this
the 2 that need replacing soon look like this
1 of the wheels ..
differnt wheel .. small scrape
Thermal Research Exhaust
SOLD
OEM Linkage including shifter. $100
http://img192.imageshack.us/img192/4994/img4099z.jpg
OEM B series Axles including mid-shaft. $120
no ripped boots ..
OEM B series axles with driver side axle ripped .. $45 for both
i have both ends it just needs new boot and rebuild
use for a core or whatever ..
http://img51.imageshack.us/img51/7237/img4101.jpg
94/95 gsr tranny since it has a sticker and not a vin (I don’t know the exact year)
came with my EK that had a swap in it .. well the swap didn’t last long and I only drove on it for about 200 miles with the bad clutch that was on that motor.. tranny made a whistling sound between 65-75 on the freeway .. a tech friend said it is the diff carrier bearing ..perfect for someone swaping out the diff and they can change the bearing then ..
been sitting the garage since July
no clutch fork
no vss
$350 FIRM
tranny was running except for the bearing made noise ..
SOLD AS IS ONLY
OBD2 Vtec dizzy's
$100 each ... i have 3
AUTO y7 trans
$100
OBD2a p72 ecu
$70
frost white DC front door handles
$30
JDM ef radiator .. will fit in DA's also
$30 picked up .. pix to come
EK window crank handles (manual windows)
$15 picked up
Stock EK dap wing (dx)
$35
92 integra GS wheels .. bad tires
$70 for all 4
have tires on them but arent the best
camber wear etc . need to be replaced soon
great daily or beater wheels
__________________________________________________ ____________________
$5 Items .. always adding to this section
basically pays for lunch
DB1 complete sunroof assembly
EK rear plate area (hatchback) .. 98-00 spec
DA battery tray
SOLD
SOLD
16 inch
falken tires
1 of the wheels ..
SOLD
no ripped boots ..
no clutch fork
no vss
$350 FIRM
SOLD AS IS ONLY
OBD2 Vtec dizzy's
AUTO y7 trans
$100
OBD2a p72 ecu
$70
$30
$15 picked up
$35
$70 for all 4
DA battery tray
