WTB 92-95 Civic EG HB parts
Hi Guys need the following parts for my HB's
2 Passenger side manual door locking mechanism
Drivers side manual door switch
(maybe the whole locking mechanism also but mostly need the little tab on the inside so I can lock the doors when I am inside currently can only l can only lock with the keys).
I need the following for my Integra
RADIATOR and Fans
ALL parts needed to add AC to my car.
Integra GSR/B16 distributor (obd1)
OBD1 fuel rail complete with injectors.
Thats all I can think of for now.
***** Giving Away Free*****you do have it pick it up, unless I already have a reason to be in your area I will not deliver these parts. Pick up is in anaheim/San Diego depending on where I am and how much notice you give me.
Dented hood, still closes but it looks like someone backed into the car denting the hood, Nozzeles for wiper have been removed
Freebie 92-95 civic and delsol manual antenna. The end was cut off some reason so it will not plug into the rear of a stereo. You will need to repair it, but its free so why complain.
Cluster Bezel it has a crack in it and it was painted silver (Its fading so it can be sanded or paint thinner or something to make it black again).
Drivers side mirror. someone folded it the wrong way so its a little loose and the glass likes to re adjust its self but if you need something to get by and be legit it will be fine.
Auto Brake/ Gas pedal nothing wrong with it other then the rubber pads have been removed.
Soon a set of no name coil overs
RADIATOR and Fans
Last edited by lshybrid195; May 24, 2010 at 04:39 PM. Reason: adding free items/ Integra parts
You can get an aftermarke metal hood for $100 after tax. There is a place down in Chula vista sells them for that. If I can't find one used for about $50 then I will just go buy one of those.
Im not looking for fiberglass or carbon or anything like that just OEM or OEM replacement.
