Clutch- master cylinder for 94 Accord
I have just replaced the clutch master cylinder in my 1994 Honda Accord. My clutch goes to the floor and will not come back up unless I manually pull it back up. I bled it for about an hr and no change. What else can I do to make it work?
make sure the master and slave cylinder are not leaking, check your clutch lines for leaks, and make sure you have sufficient clutch/brake fluid in reservoir.
mikep_95133
Dec 22, 2013 12:35 AM
i5Vigor
Jun 20, 2008 11:42 AM
