Peakboost vacuum manifold , oil pan p72 tapped for turbo, oil return line stainless
Here is a list of the parts i have for sale... Will give deals if your buying multiple items and will do my best to give you the best deal to help you guys out. I need to recoup some costs so these parts have to go. Will take OBO offers if reasonable... Will ship if needed and buyer pays paypal 3% fee on big items...
All parts are 100% working and in good condition. I will not sell parts that are broken. You will be satisfied and i have sold lots of stuff and never had an issue with anyone.
Guys all these prices are reasonable i have looked up the retail cost from DelRay Acura and everything is prices lower and if you want more then one part ill even give you a better deal. I need this stuff gone so email me for deals. Believe me everyone ive sold to has been very happy.
Email me for Fastest reply jetspeed@socal.rr.com
Pickup welcome and if your driving from far away ill make it worth your time.
ABS modulator accumulator complete unit including ABS fuse box and ABS ecu $100
Ignition switch complete working with automatic safety features will work with stick or auto. $50
1-5th OEM Brass Synchros in Good condition with no wear, asking $200 cheaper then oem and Carbon Synchros
GSR 5th Gear mainshaft gear and countershaft gear good condition asking $150
DHD NTX-2028 AMP 600Watt 300W x2 @2ohm, Works perfect no issues, asking $80
ROCKFORD FOSGATE SUBWOOFER - P1 SERIES 12" with Box 400 Watt, sounds very nice asking $130
MSD SS Blaster coil basically new just used on dyno no issues. $35
14" fan just mounted not used, 2.5 inches deep 2100 cfm. Bought for $65 asking $50 for it.
resistor box for $25
Stainless steel -10AN oil line and Earls fittings New $50
Peakboot Green vac manifold New never used $100
GSR oem distributor cap $15
http://img689.imageshack.us/img689/1931/distcap.jpg
P72 GSR oil pan tapped for oil return line, no dings or damage at all just a spare selling for $100 comes with oil plug.
New never used still in package Oil return line with 2 Earl's Barb fittings off peakboost kit, -10AN and 1/2NPT threads on fittings everything included all fittings $40
GSR rods and pistons pulled out the motor in perfect working condition $280
GSR valves 8 intake and 8 exhaust all straight no issues $160
OEM fuel rail plus end fittings ... $ 25
GSR Charcoal Canister + Evap Sensor $90
OEM trunk recently painted and shaved, prefer pick up for 2-door DC2 integras ... $200
GSR Climate Control unit missing the heater/cool slider - $40
GSR OEM fuel pump and filter used working - $50
PR3 cam gears ... $30
OEM Fuel pressure regulator with new O-ring ... $30
PVC catch can back of block $40
FITV sensor off GSR TB $30
3" PWR turbo coupler straight
3" Aluminum Turbo compressor air filter piping with about 30deg bend $40
GSR OEM Rear Driver and Passenger Camber arm $50
GSR OEM Front Driver and Passenger Camber arm $80
GSR OEM top condenser support bar $15
Integra Interlock Control Unit (Mitsuba) $50
SRS Main Airbag ECU unit with dust covers and harness(cut at impact sensor) ($900 retail) asking 250 for everything
Passenger side airbag (retail over $700) asking 100
Cruise control Auto Cruise unit $50
Please Bump and this will be updated till all the parts are sold.
can u send me a bigger pic of the lines? i cant see them. jdmferio@hotmail.com
The lines is the standard blue line that comes with the peak boost turbo kit its a -10AN. I also have stainless steel 10AN line as well if you prefer that.
