Crx spark issues, sombody help please
Old May 7, 2010 | 08:08 AM
cherroneballs's Avatar
Icon2 Crx spark issues, sombody help please
OK, first of all I purchased a pretty flawless 91 crx si. the motor and trans were out of the car but did come with the car so I put them in. then I didnt have a dizzy so I wired up an obd1 dizzy to the car. so when I turn the car over I get a couple lite sparks then no spark then a couple light sparks then no spark. I look under at the dash wiring and somone had cut and soldered wires for some unknown reason so I checked them and cant seem to find a severed wire. Is there a relay or a ground I cant see or somthing causeing this spark issue, or is the coil in the dizzy going bad because im not sure. please help im gettin frustrated I wanna drive the car.
Old May 9, 2010 | 07:58 PM
Default Re: Crx spark issues, sombody help please
anyone???
Old May 9, 2010 | 08:01 PM
BiG ChOr!Zo's Avatar
the problem is that your using a obd-1 dizzy on a obd-o motor...!!!
Old May 17, 2010 | 06:04 AM
I have used obd1 dizzys on obdo cars before I just use a conversion harness
Old May 17, 2010 | 07:55 AM
ExtraBlackRex's Avatar
This is just me..but one time I had a similar issue, took apart the dizzy and and the contact points where the rotor cap hits it's leads were bad..(Didn't even know they can wear out)..I ended up having to get another Dizzy...
U said ur getting weak spark..I'd check everything from the Dizzy to the plugs, wires included.
Old Jun 1, 2010 | 07:30 AM
Thats what Im thinking I am just going to go back to obd0 plug on my harness and just get the right dizzy thanks for your help
FOMULA91
Aug 13, 2008 05:17 AM
white90rexsi
Jun 21, 2007 01:32 PM
menappi
Apr 23, 2006 11:06 PM
menappi
Sep 21, 2005 03:41 PM
Got Milk
15
Dec 10, 2004 05:14 PM
