Jun 3's on a 2.3 stroked H22A?
Old May 7, 2010 | 06:36 AM
DelSol_F20B's Avatar
Default Jun 3's on a 2.3 stroked H22A?
I can have a set of Jun 3's cams for a VERY good price and want to know if they will perform good with my setup:
JDM H22A Longblock with F22 crank and rods
Try-Y Replica with 2.5 collector and 2.5 piping
Ported OEM Intake Manifold with 68mm Blox TB
Stock Head with Supertech Springs and retainers
H23 Long *** geared tranny
3" Short ram
with that mods i made 210 whp and 170wtq on a dynojet tuned on crome without any major head mods
what do you H22a gurus recommend me,would i make good numbers with the jun3's?
Old May 7, 2010 | 10:17 PM
Mike95lude's Avatar
Default Re: Jun 3's on a 2.3 stroked H22A?
The JUN H22A cams have a great powerband, they will do well.
Old May 8, 2010 | 08:24 AM
h23V's Avatar
f22 crank and rods what pistons do u have.
they will make good power though i'd look for about 220-230whp at wheels with the cam upgrade.
I have a similiar setup that u have should be making about the same hp u are.
I'm gonna put a 170degree thermostat in my car distributor cap rotor and new wires and dyno tuned mine.
from my trap speed and weight of the car i'm making between 203-208whp
running 9.25 at 78.12 mph in a 2901 lb accord with me in it on a 93 degree day.
my best et is 9.17 at 78.77 mph on a 20degree cooler day bout 75 was the hi that day
Old May 8, 2010 | 08:57 AM
im using stock jdm pistons machined so they dont stick out the cylinder walls.I want a cam that i dont have to rev to 9000 to the the most of the power,and ive been told that the Blox B's are similar to the Pro 2's
Old May 8, 2010 | 10:14 AM
h23V's Avatar
yes they are but for our motors it will make peak power right at 8,000rpm due to the 95mm stroke.
Old May 8, 2010 | 10:25 AM
h23V's Avatar
3" Short ram
do u have dyno graph and also where does ur hp curve start to fall off and the ported manifold u have is the iab plate gutted is it one big nasty plenum with only the 4 runners on the bottom.
Old May 8, 2010 | 10:58 AM
The car made 210whp without the ported intake manifold.Now i want to see the gains if i have any with the ported manifold.Here's a pic of the mani in the first phases of porting the lower part:
Also the dyno sheet is posted in the "post your all motor dyno" thread.
Old May 8, 2010 | 11:35 AM
h23V's Avatar
oh yea i seen it mine is almost the same is ur's except my bottom runner comes up to the iab plate
i'm running the iab plate but it's gutted and also is the top plenum i'd love to see a graph and to overlay the 2 dyno's and see if u made any gains and where.
Old May 8, 2010 | 05:20 PM
NAH2B's Avatar
are go gonna be racing at the track?
if so, you gotta rev the motor to see any et
Old May 8, 2010 | 05:29 PM
Hell yeah im gonna rev it at the track but my fear is that the 95mm crank can handle the stress at 8500+ rev.Thats why i dont want a set of cams that i have to rev to 8500+ rev to get the most Whp or Et.
Ryu
Jun 8, 2003 06:46 PM
Ryu
Jun 8, 2003 06:17 PM
hondatech
Oct 16, 2002 09:31 AM
JDMTypeS
May 14, 2002 09:51 AM
