2001 Honda Accord Low oil pressure light
Old May 6, 2010 | 09:43 PM
Jas29's Avatar
Default 2001 Honda Accord Low oil pressure light
I was wondering what would make the low oil pressure light to come on taking hard left turns. This never happened before and it only happens on left turns its a 2001 Honda Accord Ex.
The oil level is fine and this only happens when you take hard left turns, we tried the same thing on right turns and speeding up and breaking hard but neither of those turned the light on. The light turns on and then off but stayed on for awhile once.
Any advice will be appreciated
Old May 6, 2010 | 10:34 PM
phootbag's Avatar
Default Re: 2001 Honda Accord Low oil pressure light
Conincidental bad connection at the oil pressure sending unit connector just above the oil filter. Or, you actually have low oil. Or, you are cornering WAY too hard
Old May 6, 2010 | 10:56 PM
Jas29's Avatar
thanks for the advice and we weren't cornering that hard
Old May 7, 2010 | 10:37 AM
Jas29's Avatar
hey i was wondering if it could be something wrong with the oil pickup tube and screen
Old May 7, 2010 | 05:02 PM
phootbag's Avatar
Yea. There could. I would check the wiring to the oil pressure switch first, you don't have to remove the oil pan for that
Old May 7, 2010 | 06:36 PM
Jas29's Avatar
Thanks will do that tomorrow and change the oil hopefully it works out
Jacob O'Neal
Dec 26, 2018 06:29 PM
nmesolella
Honda Accord (2013 - 2015)
Jul 14, 2018 06:38 AM
MyUsernameName
Jun 15, 2017 02:06 PM
tdsilk
Mar 16, 2008 02:36 PM
siis2fast
Nov 4, 2005 04:54 PM
