blowin ecu fuses???
Old May 6, 2010 | 09:18 PM
eg8_civic_253's Avatar
Icon6 blowin ecu fuses???
For some reason my car keeps blowin ecu fuses. My grounds all look good and my stereo stuff isn't shorting out. My fuel pump doesn't turn on either and as soon as the car is in the on position it blows. The car still cranks when it blows though. Any suggestions??
Old May 6, 2010 | 09:45 PM
Default Re: blowin ecu fuses???
Also the check engine light is constant and won't show a code when I jump it.
Old May 7, 2010 | 07:43 AM
today i unplugged the ecu and tried it. blew a fuse. unplugged the dizzy. blew a fuse. took out the main relay. FUSE STILL GOOD. any suggestions?
Old May 7, 2010 | 10:16 AM
gsrcoupee's Avatar
it has to be a bad ground or something is touching that shouldnt be im not for sure tho.. my old integra was super slammed and it kept blowing ecu fuses when i put in reverse and we could never figure it out. i parked it for a while and one i day raised it up a couple inches and it never blew another one lol.. but good luck man wiring problems like that sucks!
Old May 7, 2010 | 10:33 AM
Former User's Avatar
Check the main relay for a short. Also plug the main relay back in and unplug the IACV, fuel injectors, O2 sensor, or EVAP purge valve to see whether the fuse stops blowing.
Old May 7, 2010 | 12:12 PM
thanks for the help. i tried to start my car today with a new fuse and i toasted my underdash harness. i think its about time for a new one.
Old Apr 30, 2025 | 10:21 PM
Deadman2425's Avatar
had this problem, the other day. Fuel pump burning out the fuse. Unplug The fuel. pump or fuel pump relay under driver side dash long rectangled. Relay block left side tucked behind a square computer box.
crookson speed
Feb 25, 2014 12:02 PM
jdmgsr420
Honda CR-V & Element
35
Mar 4, 2012 06:10 AM
91b18a1ls
Nov 23, 2010 11:29 AM
Racewerkz
Dec 12, 2006 12:01 PM
