Zc motor
I got a zc motor but it didnt have a crank in it. Is there any crank i can use besides the zc like maybe a d series. also what are some good factory pistons upgrades. thanks for any help
13310-pm6-010 is the part number for the crank for both the 1.6L SOHC and DOHC ZC engines. The 1.6L SOHC ZC is near identical to the d16a6, however to be 100%, give Honda call and see if that part number matches any US delivered engines, and if it does, then you've got a match
for the OP:
all of the SOHC D16 crankhafts from 88-95 will work in the DOHC ZC as will the crankshafts from the 86-89 Integra D16A1 and the 84-95 JDM DOHC ZCs - the only thing you need to watch for is that all of the crankshafts up to the 89 models had a 22mm diameter front snout where the timing belt gear and crank pulley go on - 89 and up had a 24mm diameter front snout - you need to match the timing belt gear and crank pulley to the crankshaft
do you have the timing belt gear for the crankshaft for the DOHC ZC? the DOHC ZC gear is the only one that will work and they are hard to find, especially the 22mm diameter ones
there are no factory pistons that are better than the DOHC ZC pistons for use in the DOHC ZC
that part number is correct for the 89 and up crankshafts with 24mm diameter front snout, however, 88 models had a crankshaft with a 22mm diameter front snout and are part number 13310-PM6-000
only the DOHC ZC timing belt gear for the crankshaft will work on the DOHC ZC - the DOHC ZC gear has 17 teeth, the 86-89 Integra D16A1 gear has 20 teeth and all of the SOHC D-series gears have 19 teeth
I have a 93 civic dx with a zc in it. My problem is my passenger side half shaft is too short, the tripod berrings come out of the berring sleeve. What kind of half shaft can i use thats a little longer?
this question belongs over here...!!!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/
hopefully some1 can help me out i got a zc motor and the ignition timing is off, it should be at 16 degrees btdc but its at 9. im not exactly sure what to do, but i would like to totally reset it jus not sure how????
I did a swap in my 89 crx and put in a 1.6L dohc zc and now a dont have spark at the distributor and i need to jump the connections on the main relay to get my fuel pump to work. i replaced both but my problem is still there. if anyone knows why it would be a huge help. did i just miss a ground??
4door93civic
Feb 1, 2008 08:46 PM
CRX_Phantom1
Nov 24, 2005 05:10 AM
Disco Stu
Jan 14, 2003 12:22 AM
