Y1 trans. and starter help
Old May 6, 2010 | 05:15 PM
brian1991's Avatar
Icon2 Y1 trans. and starter help
i just swapped a y1 trans into my car and now i need a starter cause the starter i have dosent fit (sm-402-01) does anyone know what starter is needed the only one i can find for an 88-91 b16a sir is the( sm-402-01 n ).. is this the correct starter.....please help....thanks
Old May 6, 2010 | 05:26 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: Y1 trans. and starter help
90-93 Integra 5 speed starter will work
Old May 6, 2010 | 06:09 PM
brian1991's Avatar
do you know what the starter is by any chance the numbers, also is there any usdm starters that will work or do if have to stick with a jdm starter
Old May 6, 2010 | 06:32 PM
brian1991's Avatar
bump
Old May 6, 2010 | 07:01 PM
D16SiHatch's Avatar
deetz just said what usdm starter would work..
Old May 7, 2010 | 02:31 PM
brian1991's Avatar
90-93 intregra starter dosent work ive tried it.....im lost on what to try
Old May 7, 2010 | 02:46 PM
Deetz's Avatar
Crazy Honda Guy
I'd suggest you try again!!!
The Y1 tranny is the exact same tranny housing as any DA integra. If you want me to be real specific, go find a 1990 Integra starter from a RS, LS or GS model from a 5 speed model, there should be no reason it shouldn't work.
It is possible you didn't have the starter you "thought" you had the 1st time. Otherwise, it could be a wiring issue if it doesn't go.....or something is up with your flywheel.
jdm/usdm starters, lol, same damn thing!!!
Old May 7, 2010 | 04:03 PM
brian1991's Avatar
i put a 8lbs alum. flywheel (xtd) on could that be the problem
Old May 7, 2010 | 04:08 PM
Deetz's Avatar
Crazy Honda Guy
Why would you buy the absolute cheapest flywheel on that market??? bottom of the barrel.
ACT for the wanting.......we are talking about your drive train, important stuff!!
Old May 7, 2010 | 04:49 PM
crx_si-r's Avatar
Honestly all 90-01 integra starters work and all usdm b16 starters will work. It makes no difference if the integra starters are vtec or non vtec as long as you get a 5-spd. I'm running a 92 gsr (b17) on my ys1 transmission. And my old 90 b18a1 starter worked fine on my ys1 till it crapped out on me.
Old May 7, 2010 | 04:51 PM
crx_si-r's Avatar
Makes no difference. The tooth count will be the same. I am running an 11lb act Flywheel, and the b17 starter works fine for me.
Old Apr 21, 2023 | 01:58 PM
Deelow760's Avatar
Hello well I have a sm-402-01 and I don't need it if you still need one for your car hit me up
Myb20integra
Sep 15, 2014 02:14 PM
hondachris1994
Aug 3, 2006 02:03 PM
