96 honda accord 2Dr antenna
Old May 6, 2010 | 05:11 PM
clowery89's Avatar
Default 96 honda accord 2Dr antenna
where is the antenna located i cant find it and i wanna do something to make it stronger i hate sitting next to the big trucks and lossing my radio....
Old May 6, 2010 | 06:51 PM
93EXR's Avatar
Default Re: 96 honda accord 2Dr antenna
Im a mechanic and ive seen alot of cars- to the best of my knowledge on that car the antenna should be located on the drivers side rear panel near the trunk. Is it possible that a previous owner had shaved the hole??
Pull the carpet from the drivers side in the trunk youshould see something there like the power antenna motor or maybe the hole bondo-ed up where it used to be-
If thats the case you can carefully open it back up an put a stock antenna back in- let me know what happens. good luck i hate poor reception too!!
O yea! i also know there is a service bulletin on poor reception in that particular model- it tells u to remove radio and clean corrosion from antenna coaxial cable in rear of radio. clean it with a scotch brite pad or some really really fine sandpaper then put some dielectric grease on it - you can get some from local parts supply
Old May 6, 2010 | 07:03 PM
The-Kid's Avatar
It is actually integrated to the rear window. However, I do not know if there's any way to make it stronger. I'm sure someone will post something.
Old May 11, 2010 | 09:41 AM
clowery89's Avatar
ok you guys this is strange i found the antenna kinda.... i followed the wire back ... i does not go to the window or the trunk ... but its bolted to my roof under the headliner.... any ideas
Old May 11, 2010 | 09:59 AM
The-Kid's Avatar
Usually the wire would continue onto the windshield. Those lines running across the rear window is not all part of the rear defroster. Some of it belongs to the antenna. Most likely the upper part. In any case, there are like in-line radio antenna booster. I do not know if it works or not. You might want to give it a try...
Old May 11, 2010 | 10:19 AM
clowery89's Avatar
ok and one more ? when i start my car the 4th drive light comes on for a sec whats that mean
Old May 11, 2010 | 10:31 AM
The-Kid's Avatar
Like when you put it onto (2)/second click (right before engine start)? It's normal. I don't know what it exactly means, but I have noticed it corresponds to the fuel pump priming up. You would hear the fuel pump and as the light goes off, so does the fuel pump. Maybe it's just a pre-check for all the systems. I hope someone else can contribute to this question...
Turn to 2 and see if it goes away first. Then start the car. But from what you're describing, sounds normal.
Old May 11, 2010 | 10:35 AM
clowery89's Avatar
yeah thanks i didnt really see it before i guess .... i really cant wait till i have the $$$ to do the 5 speed swap i hate auto cant ever trust it
khronicboy420
Dec 31, 2008 07:58 PM
sony224422
Audio / Security / Video
Jun 17, 2006 11:31 AM
sony224422
Jun 15, 2006 05:22 PM
xunkn0vvnx
Feb 25, 2004 06:13 PM
