Need HELP - How do you test ICM or Ignitor '88 CRX ???????
Old May 6, 2010 | 04:45 PM
civichb20's Avatar
PM Garage
Icon2 Need HELP - I Tried and Tested EVERYTHING '88 CRX ???????
I Replaced Ingnitor
Hey I need help figuring what is wrong with my 1988 Honda CRX Si I look everywhere on HT and I am finding threads but no specifics. I have tested almost everything that my OEM Manual and Haynes Manual describes. Lastly there was a bunch of Red Powder in the distributor housing could this mean my Crank Angel Sensor is going out.
Thanks In Advance
I have TESTED the following already
1. Fuel and pump - Good
2. Coil is a little out of spec 8 OHMS - Range is suppose to be 5-7 OHMS?
3. Replaced Ignitor
4. Car cranks over but will not start.
5. Replace with a good ECU because last ECU was throwing some funky codes like 21 ?
6. Red powder in Distributor housing could this be the Crank Angle Sensor going bad?
7.
Old May 6, 2010 | 09:40 PM
civichb20's Avatar
PM Garage
Default Re: Need HELP - How do you test ICM or Ignitor '88 CRX ???????
dang nobody ?
Old Dec 11, 2011 | 03:07 PM
davegt27's Avatar
did you ever get your car Fixed?
Davegt27
civichb20
May 8, 2010 05:15 PM
barney_SI
Nov 30, 2009 05:09 PM
superbeastcrx
Jul 23, 2005 11:25 AM
South Bay Surfer
Jan 25, 2004 03:44 AM
