Steering rack interchangeability?
Old May 6, 2010 | 01:30 PM
ridgeapd's Avatar
Default Steering rack interchangeability?
Will a manual rack from a 91 CRX Si fit onto a 90 Hatchback DX (that has POWER steering) without modification?
I thought I saw a conversation somewhere about complications from the rear crossmember design. The problem being that there is one crossmember for the manual steering rack, and a different crossmember for the power steering rack.
I didn't find a specific answer in the FAQ.
Old May 6, 2010 | 09:52 PM
greenracer713's Avatar
Default Re: Steering rack interchangeability?
?? i thought only the sedan came with power??
Old May 6, 2010 | 10:12 PM
sanimalp's Avatar
$cat /dev/urandom
that's a good question. my guess is that you will need the rear crossmember from the power steering car.. but that's a guess.
Old May 6, 2010 | 11:32 PM
Clipsed's Avatar
YES-There are two different cross members for manual and power steering racks
YES-You can bolt a non power rack to a power rack cross member with both bushings.
Old May 7, 2010 | 11:33 AM
ridgeapd's Avatar
Thank you very much, Clipsed. I'm changing the racks next week.
It took a lot of views to get this answer. I bet if I had posted pictures of my "hella tyte" JDM muffler bearings, people would have had all kinds of input.
Old May 7, 2010 | 11:34 AM
ridgeapd's Avatar
Excellent input.
Old May 7, 2010 | 11:45 AM
Tyson's Avatar
no, i dont think so.
Old May 7, 2010 | 01:15 PM
ridgeapd's Avatar
You don't think they will swap?
or
You don't like muffler bearings?
Old May 7, 2010 | 01:24 PM
Tyson's Avatar
i just wanted to add some more worthless views and excellent input.
Old May 7, 2010 | 06:41 PM
Clipsed's Avatar
no problem
Old May 17, 2010 | 03:15 PM
ridgeapd's Avatar
Rack Swap Completed.
My thoughts... there are 2 "sides" of the steering rack (be it manual or power)... The side that bolts directly to the crossmember (driver side) and the side that is held in place with a bracket (passenger side). The Power rack has a larger circumfrence than the manual rack, and therefore has a larger bracket. The brackets are differentiated by "PS" or "MS" stamped on the bracket.
There is a rubber bushing surrounding the rack where the bracket bolts on. To do the swap, I simply put the bushing from the power rack over the manual bushing and bolted it all up with the "PS" bracket. Its solid, works great, and looks great.
I'm acquiring a "MS" bracket, and hope to eliminate the power steering bushing.
gotenz90640
Mar 19, 2016 03:57 PM
L0WL1FE
Jan 12, 2012 06:38 AM
NOman0608
Jan 25, 2009 07:17 AM
sohc_freak
18
May 24, 2006 07:56 PM
