brake lights not working need help
Old May 5, 2010 | 08:32 PM
oh_dam's Avatar
Default brake lights not working need help
i just notice tonight that when i had stepped on my brake lights it did not turn on at all, i know the bulbs are good because when i turn the headlight switch one turn everything turn on but when i step on the pedal nothing happens
Old May 6, 2010 | 01:50 PM
770_dc2's Avatar
Default Re: brake lights not working need help
could be your brake switch thing under ur brake pedal had the same problem on my 96 teg and replaced that part and everything was good and working again also check your fuse as well as ur wires could be a lose wire too hope this helps
Old May 6, 2010 | 06:28 PM
a97b18b's Avatar
I'd check the switch also. if ya got a meter you could check for voltage. Check for loose connections.
CR-X_B20
Jul 6, 2013 06:36 PM
804tuned
Jan 14, 2010 07:50 PM
summey
Feb 6, 2006 07:29 PM
virusx
Apr 28, 2005 12:13 PM
X2BOARD
12
Mar 1, 2005 11:36 AM
