GSR Trans oil change.
Hi everyone, i did a lot of research but couldnt find a nice picture of where the drain and fill bolts are. If someone could post one picture and point out the drain and fill bolts i will appreciate it! And i went out today and bough 3 quarts of MTF from Honda dealer, do all 3 quarts must go in or how much i should fill in? Thank you!
The drain plug is on the side of the tranny, near the bottom, basically pointing out the passenger wheel well. It's the only bolt that doesn't have a bolt head on it. It has a square hole that you stick a 3/8" ratchet in.
The fill plug is a 17mm bolt above and a little left of the drain plug. I prefer to just leave it alone and pull the vss. It's easier to fill through the vss hole since it's right on top.
The tranny takes 2.2-2.3 quarts.
https://honda-tech.com/forums/showth...r+transmission
you didnt research. it took me no more than 2 minutes to find this.
