I have a ls and I am missing some of my cam caps can I get some off another ls??
Old May 5, 2010 | 12:44 PM
89civicb16a1's Avatar
Default I have a ls and I am missing some of my cam caps can I get some off another ls??
I was wondering if I can get some cam caps on another ls or will it run wierd thanks
Old May 5, 2010 | 01:45 PM
Spawne32's Avatar
Default Re: I have a ls and I am missing some of my cam caps can I get some off another ls??
go get some cam caps off another LS and be on your way :p
Old May 5, 2010 | 02:36 PM
nsxter's Avatar
tell him the whole story if you borrow cam caps from another head they will need to be lined bored
Old May 5, 2010 | 03:34 PM
wunfstgsr's Avatar
Loved
Community Favorite
At least some one knows what there talking about here, take the head and cam caps to the machine shop and have them line bore the caps and redo the head and whatever else you want to do with it.
Old May 5, 2010 | 08:18 PM
seanbev24's Avatar
You can probably find a complete LS head for cheaper than the machine shop will charge you to line bore yours. I'd consider a head with missing cam caps a paper weight.
Old May 5, 2010 | 08:35 PM
nsxter's Avatar
i would consider Spawne32 a paper weight
Old May 6, 2010 | 04:13 PM
so pertty much your saying is that my ls head is useless what if i get all the cam caps and cam shafts??? or something like that
Old May 6, 2010 | 04:26 PM
Spawne32's Avatar
i dont see anything in my service manual about having the cam caps line bored, but ill ask around
Old May 6, 2010 | 04:33 PM
ihaterust's Avatar
then dont line bore it and have your cams seize in the head, snap the tbelt and smash the tops of your pistons. ls heads are paperweights to begin with. try and find a b16 head for cheap somewhere
Old May 6, 2010 | 04:45 PM
Spawne32's Avatar
you guys like to talk alot, how about posting specifications for the line bore
Old May 6, 2010 | 06:27 PM
seanbev24's Avatar
I don't have specifications, nor have I ever had anything line bored. Mostly because I keep track of my parts and wouldn't consider buying a head with missing caps.
The reason you can't just use cam caps from another head is because during the casting/machining process, they are cut after the bore is made. Because of this, a cap from another head (or even mismatched from the same head) will never fit the same. That is why you can't just go buy one from Honda.
I'm not here to talk ****. Have people used mismatched parts and got away with it? Sure. That still doesn't make it right and can cause big problems.
To the OP, people practically give away LS heads. Just find a complete one and be done with it.
Old May 6, 2010 | 06:39 PM
nsxter's Avatar
we talk alot because we know are **** unlike you
Old May 6, 2010 | 07:03 PM
Spawne32's Avatar
fair enough
Old May 6, 2010 | 07:06 PM
Spawne32's Avatar
who are you?!?!?
Old May 6, 2010 | 07:08 PM
Blahblah718293's Avatar
you can try it, whats the worst that can happen?
Old May 6, 2010 | 07:18 PM
dntnedvtec's Avatar
I am not picking sides, but you didn't give him the specs....And a answer like that is very childish.
Honestly, I have never heard of such a thing. I have swapped out cam caps at least four or five times. Why? When one gets dinged inside, I toss it and swap it out. I nevered had any issues...But, I could be wrong...
Old May 6, 2010 | 07:19 PM
Spawne32's Avatar
like i said, on the engine rebuild section of my 94 service manual, theres nothing about cam caps needing to be honed or line bored
Old May 6, 2010 | 07:27 PM
dntnedvtec's Avatar
A quick sweep throught the Haynes, and I didn't see it either....
Old May 6, 2010 | 07:33 PM
Spawne32's Avatar
talked to a buddy of mine and he said its possible if you dont have them line bored that it could clamp down on the cam too tight if its not the proper spec, sometimes they can be taller or shorter, so id talk to a machine shop about it, strange though that i dont see any specifications for it in the service manual
Old May 6, 2010 | 07:36 PM
Spawne32's Avatar
wait, scratch that, i found it
Old May 6, 2010 | 07:41 PM
Spawne32's Avatar
http://www.ehow.com/how_2142943_use-...learances.html
Old May 6, 2010 | 07:51 PM
dntnedvtec's Avatar
hmm......I still don't see it, but I have no problems
Old May 6, 2010 | 08:15 PM
seanbev24's Avatar
Here's the issue I have with the clearance spec... When you mismatch parts that a bore was cut through, even if the plastigauge seems ok, there is no way that the mismatched bore will be round.
The specs are there to make allowances when the cam has been wearing evenly in that journal. There is no way you can take a cap that has worn in a different engine and have the bore still be true.
Yes people have done it without problems, but it's still not right.
Old May 6, 2010 | 08:26 PM
nsxter's Avatar
who are you?!?!?
someone that knows more than you
Old May 6, 2010 | 10:39 PM
Acuronda_SloTeg's Avatar
you must have a sad past with experiences of non vtec setups cause i run non vtec to show peeps that it can walk vtec setups without expensive mods. i have a link to my vids for proof
