ABS and Polyurethane lip difference
Old May 5, 2010 | 09:22 AM
SeanK325's Avatar
Default ABS and Polyurethane lip difference
is one harder than the other? which is more prone to cracking/breaking? Which is more prone to lose the paint applied to it?
Old May 5, 2010 | 09:36 AM
boxeocampeon's Avatar
Default Re: ABS and Polyurethane lip difference
polyurethane is def better. ABS is more prone to cracking but its way better than fiberglass. go with the urethane lip
Old May 5, 2010 | 10:48 AM
-Gambit-'s Avatar
true
Old May 5, 2010 | 10:52 AM
kaduku_'s Avatar
p/u is the shiznit. abs stays shiny for awhile but one bump too high is all it takes to destry it. if your going to put lips on the front and rear you could be safe with abs in the rear but i would definately recommend the p/u for the the fronts.
Old May 5, 2010 | 12:26 PM
SeanK325's Avatar
thanks guys. found a guy selling a white ABS front lip for 25. just wanted to know if it was worth the money.
Old May 5, 2010 | 09:25 PM
what lip are you looking at?
Old May 5, 2010 | 09:34 PM
SeanK325's Avatar
type r front
Old May 5, 2010 | 09:44 PM
get urethane then. Password jdm sells a urethane replica lip for like $180. u gaurantee a cheap one will not fit well
Old May 5, 2010 | 09:46 PM
SeanK325's Avatar
$180 is a long way from $25, but I get what you're saying. I'll just save some extra cash and buy the right part in time.
Old May 5, 2010 | 09:49 PM
i mean you can probably get one for about $100 thats decent quality, check out weksos industries also and inline4.com Im just saying you probably will regret the $25 one later on
Old May 5, 2010 | 10:15 PM
patrEK9's Avatar
check out carpartfreaks, they're in the sponsor marketplace i think. they have poly lips for cheap and are good quality. had mine for a few months now and still in perfect shape.
Old May 5, 2010 | 11:36 PM
out_of_order_eg6's Avatar
polyurethane is the way to go..much more flexible and almost crack proof!!
DC4R27
Mar 11, 2012 08:07 AM
EcHoB18C1
Apr 23, 2009 10:45 PM
JaeEK
Paint and Body
Feb 10, 2008 09:13 PM
NickW
Sep 30, 2006 02:58 PM
kaspur_eh
Aug 4, 2004 01:59 PM
