iacv 3 wire plug to 2 wire plug
Old May 5, 2010 | 04:39 AM
fibereater's Avatar
Default iacv 3 wire plug to 2 wire plug
I have a 96 gsr motor that is going into a 96 dx using the stock dx harness and an obd1 ecu. Are there any good links out there that show not only the wire conversion at the plug but also what has to be done to the ecu plug?
Old May 5, 2010 | 05:55 AM
dpetro1's Avatar
Default Re: iacv 3 wire plug to 2 wire plug
as for the engine harness you should be able to clip the plug and wire in a 2-pin plug. one pin to a12 on the ecu and one pin to 12v source
Old May 5, 2010 | 08:34 AM
97twodoor's Avatar
Followed the above diagram when i did my swap, and it's perfect.
Old May 5, 2010 | 10:10 AM
3starz's Avatar
^^Like what he say. Its pretty simple. Don't forget to get the OBD2A to OBD1 Conversion harness since you are using a OBD1 ECU. P72 or P28 ECU? I think the P28 ECU minus the IAB and need a second knock sensor. P72 you need to add IAB.
danteisme
Audio / Security / Video
Sep 29, 2016 04:33 AM
komat
Nov 3, 2010 06:46 PM
streetracerjoey210
Jul 18, 2006 09:37 PM
Monkey Fing a Coconut
May 28, 2005 06:58 PM
95accordh22a
Mar 15, 2005 11:48 AM
