MiniMe in a 90 si
I have a 93 minime that im wanting to put in my 90 si. What all do I need to do? Im going obd1 on it. I have a p28 ecu. I know I need the ecu jumper harness anything else?
-OBD1 distributor and jumper harness (or repin your plugs)
-Reuse your injectors or delete your injector box and use the OBD1 injectors
-You'll have to modify the drivers side motor mount a bit to get it to fit (the one on the block) if you are using a post 91 block
-Run wiring for 4 wire O2, VTEC solenoid, VTEC pressure switch
-Depending on your block you may have to rewire the fan switch to the 92+ location on the thermostat housing
PM me for any questions you may have
jmanjdm
Dec 10, 2014 11:44 AM
90hatchblack
May 14, 2007 12:35 PM
importgod21682
Dec 25, 2006 09:33 AM
