vtec question
now dont say SEARCH because i did and i didnt find anything. . . i thoguht that vtec was 4XXX rpms . . .now i just got on my intake on my gsr and i hear it get nmuhc louder higher pitch at about 5800 5900 is that the vtec? why would an intake make that so much louder and higher pitch??
in a gsr there's two stages of vtec...
first stage 4400
second stage 5700
on stock - almost stock gsrs you can only hear/feel the secondary runners (stage). once you get i/h/c/e you'll feel the first stage too. if you listen closely you can probably hear somewhat of a sound change at about 4400, but i mean CLOSELY. good luck.
first stage 4400
second stage 5700
[QUOTE]in a gsr there's two stages of vtec...
first stage 4400
second stage 5700
QUOTE]
close but not quite true.
the first stage of vtec is below 4400 and the second stage is above that.
the intake is also dual stage. first is below 5600(5700?) and second stage of the intake is above that.
in an unmodified gsr u can only hear the intake switching over
first stage 4400
second stage 5700
QUOTE]
lol!! 2 stage vtec...o man.
im gonna save yall from getting flamed as someone said that before and everybody just jumped on him.
the secondary openers are part of the intake manifold. it had nothing to do with vtec. it will still operate if your vtec is disconnected.
i know what u guys are trying to say, but others may take advantage to flame
the vtec is two stage, this is not hard to understand. u say the intake it dual stage low air flow, and it opens up to a second stage with more flow. the cams do the same, less air at low rpm and at 4400 the 'second stage' cam lobes r engaged and more more air is let in, not to mentiion the other fuel changes.
VTEC is 2 stages? Huh?
VTEC kicks in at 4400 RPMs considering the oil pressure is correct.
Your Secondary Runners located in your intake manifold will open up at approximately 5700. At 5700 the butterfly valve on your IM open up using short runners, which basically rams more air into your head.
don't answer if you don't know what the hell u are talking about, end up giving people wrong idea's...malicegsr is correct, it has nothing to do with vtec, just the intake manifold on the gsr...
Yes, but the way air enters has nothing to do with VTEC. The computer senses a point in the RPM band and switches to a more aggressive cam profile. Basically, that would just about sum it up. When the secondary runners open up, it's just another Honda trick to get the most out of the engine. Short primary runners work well at low RPM, and longer secondary ones work better up top.
edit: To make things clearer, when the secondary runners open up, this does not trigger VTEC again, nor does it switch to more aggressive cam profiles.
[Modified by dom93hatch, 8:07 PM 9/11/2002]
if you look at it from another point of view.. then yes technically it IS two stage. one set of low cam profiles for low RPM operation and the other for high RPM use
Guest
Posts: n/a
first stage 4400
second stage 5700
first stage 4400
second stage 5700
is this Intake manifold 5700 rpm thing just for vtec integs or is it in all the civics and other hondas?
