rattling sterring wheel!
hi all i just got back from deployment and i started driving my car and when ever i brake i have this really big rattle in my steering wheel i just got my tires rotated and balanced what you think it could be maybe the rotors???? thanks for the help!!!
sweet ill go ahead and check on the rotor and upgrade but first ill check rotors to see if warped. ill keep you posted if anything else happens thanks guys!
ok today while driving the rattling and noise got really bad when i was on freeway but this weekend i will not be using my vic! could it be an alighnment issue?
Actually... my steering wheel would vibrate severely when I would get on the brakes anywhere from 60-80mph. I recently replaced the suspension, motor mounts and the compliance bushings (on the lower control arms) and the problem went away. I still have some vibrating when I get on the brakes from the rotors having uneven wear and hot spots but the problem is nothing like it was before.
My car has 113k miles on it by the way.
fixing all that other stuff just minimized the vibrations caused by the rotors being warped
You need to fix the cause of the problem before you start replacing every bushing on your car.
Damn some of you guys are retarded.
And if you're still skeptical about whether or not to replace the rotors, it takes 2 minutes to remove the wheel and use a dial indicator to measure the run-out on the rotors. That will tell you if/how badly they are warped.
Yep I am a retard. Because I fixed my car. My brakes dont shake or rattle anymore. But i am a retard. HAHA...
sagacious
14
Jul 29, 2012 08:56 AM
james p.
13
Jun 5, 2005 08:17 AM
RacerXintegra2k
Sep 25, 2002 05:03 PM
