i now hear a new chattering noise under my hood.. its near the tranny it sounds like.. what is it?
Old Sep 11, 2002 | 01:46 PM
civicracer1993's Avatar
Default i now hear a new chattering noise under my hood.. its near the tranny it sounds like.. what is it?
its not that loud but its noticable.. mostly on acceleration... it sounds like when u pull a spark plug out when the engine is on.. but a bit faster than that? any ideas? it sounds like its near the tranny but i could be wrong..
mike
Old Sep 11, 2002 | 02:47 PM
Lt. Dan's Avatar
Default Re: i now hear a new chattering noise under my hood.. its near the tranny it sounds like.. what is i
any change when you push in or let out the clutch?
Dan
Old Sep 11, 2002 | 03:08 PM
B16CRX's Avatar
My first two guesses would be clutch or water pump. Can't really tell without hearing it.
Old Sep 11, 2002 | 05:32 PM
Leets's Avatar
I had a similar problem and started sh*tting bricks thinking the flywheel was gone. Popped the hood to find the clutch cable came out of the brackets and was just rattling against the hood. Just look around under the hood first... trust me.
Old Sep 11, 2002 | 05:35 PM
ScottEK's Avatar
Mine has a loud noise when you have the clutch let out, but when you push it in it magiclly goes away. It's getting worst too.
Old Sep 11, 2002 | 05:52 PM
FUP23's Avatar
New User
Im betting your flywheel is getting loose ...Or bad throw bearing might be the problem to
Old Sep 11, 2002 | 06:11 PM
i checked for loose stuff but ill check again but it sounds like its the tranny but it really shouldnt be because i just got a brand new tranny and clutch put in last june..it better not be going already.. when i push the clutch theres no difference .. i thought it could be somthing with the DPFI carb and junk but im not sure.. cause it is louder on acceleration.. but the car runs fine so i dont know...
Old Sep 11, 2002 | 06:42 PM
Lt. Dan's Avatar
If you have a noise with the clutch out, that goes away when you push the pedal in, more than likely you have a bad Mainshaft bearing.... If that's the case, I've got a tranny I'll sell you...
Dan
Old Sep 11, 2002 | 09:29 PM
ThatRicerDaniel's Avatar
close to your distributor cuz distributors click after awhile
Old Sep 12, 2002 | 04:23 AM
therealciviczc's Avatar
Dan
Give this man a cigar.... I'd put my $20 on this being your answer....
Old Sep 12, 2002 | 07:48 AM
hybridmike's Avatar
Dan
i second that i just had one do the same thing
Alchmst25h
Dec 9, 2007 07:57 PM
NazVil86
Oct 18, 2006 08:18 PM
PreludeMTX
Aug 27, 2004 08:47 AM
big tuner
Jul 29, 2003 09:40 PM
Fokis05
Apr 18, 2003 07:53 AM
