91 B18 CRX Help ( pics attached )
Old May 4, 2010 | 02:10 PM
burban89's Avatar
Default 91 B18 CRX Help ( pics attached )
So I am trying to figure out what the loud pop was on the driver side while I was going 10 mph in a straight line. Then at about 20mph there was alot of clunking like noises.
In the first pic the boot that is circled is ripped and no grease at all is in it. There is grease thrown all over the bottom of the car.
The axle looks ok, what is the best way to test it?
All the bushings are smashed and cracked, can i buy a complete kit somewhere?
Also the grease seems to be around the axle and not the split boot??
Thanks for all the help!!!
Old May 4, 2010 | 02:18 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: 91 B18 CRX Help ( pics attached )
1st pic is an inner tie rod
If your bushings are shot, look into either oem replacement, or Energy Suspension sells a full poly upgrade if interested.
If you axle boot is ripped, you can either replace the boot, or, if you have clicking when turning, but buy a whole new shaft, they are cheap
Old May 4, 2010 | 02:30 PM
burban89's Avatar
The boot on the inner tie rod is what is ripped.
I can not see or feel a tear on the axle boot.
The clunking is going in a straight line not turning.
Old May 4, 2010 | 04:13 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
...sometimes the rips happen in the creases... IT IS OBVIOUS YOU HAVE A TEAR IN THE BOOT BECAUSE OF THE GREESE ON THE LCA MOUNT!!!
Your upper ball joint sure doesn't have a lot of threads showing... are they even tight? There is not even a cotter pin in it... who ghetto rigged this car?
Old May 4, 2010 | 04:42 PM
burban89's Avatar
HAHAHA "who ghetto rigged this car"
I have been saying that for 2 days. Everything I have taken apart is missing a bolt, nut, or something.
I put the tire back on and set it down for the night. I will check the nut tomorrow. I did yank up on it and it may have moved a hair but not much if it did.
I just yanked on the axle to and it did have some up and down play. Maybe a 1/4"???
I am replacing and adding all the missing bolts as I go through it. I bought it Sat from a kid in Fla.. Got it cheap but having to do a lot of little tedious fixes.
Old May 4, 2010 | 06:17 PM
BrayzieEF9's Avatar
x2
Old May 5, 2010 | 04:25 PM
burban89's Avatar
Changed the axle today and no more clunking. Added pins to everything. I am going to change bushings and all next.
It looks like someone tried to repack the boot and instead of a metal strap they used a thin panduit strap. guess it did not hold very well.
01ethansh
Dec 17, 2008 12:15 PM
DcLs
Oct 31, 2008 10:47 PM
ShinotakuX
26
Oct 18, 2008 06:38 PM
B18CivicEH2
Mar 19, 2007 03:13 PM
Touge Tuning
May 18, 2006 04:22 AM
