vents only working on highest setting
So the other day my air vents stopped working unless I put it on full blast. anyone know what this could be? I searched and didn't come up with a for-sure answer. Thanks
On most imports that I've seen the lower speeds have resistors in a "block" (decreasing in resistance obviously as you increase blower speed) and HI is full resistor-less power; usually wired independent from the resistor block. It is still possible for individual lower speeds to die out however, despite them all being in a "block".
