Crazy sound from my rear brakes of 1996 Accord
Old May 4, 2010 | 07:00 AM
Rob_KCMO's Avatar
Default Crazy sound from my rear brakes of 1996 Accord
I have a 1996 Accord Ex (138000 miles). Recently I have changed (300 miles ago) all brake rotors and pads. My rear brakes are making a crazy sound. Suppose you take a syringe and remove the needle and hold the inlet. Now if you try to take the plunger out you will not be able to do that as vacuum will create. If you apply more force to take the plunger out, then the plunger will come out with a loud sound. I am hearing similar kind of sound from rear brakes when I press the brake. Moreover, the sound is not coming every time. May be 3-4 times out of 10 times I press the brake.
As I said all rotors and pads are new (300 miles ago). When I start the car I listen some grinding sound from the front brakes. This goes after driving 10-15 min.
I will highly appreciate if anybody kindly explain the reasons for these facts and the solutions.
Thank you.
cindyannt
Suspension & Brakes
Jun 16, 2017 03:24 PM
tsim
Jun 26, 2009 05:41 AM
nist7
Aug 20, 2006 09:59 PM
96AccordExCpe
Jun 17, 2003 07:06 PM
