Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
need help with subframe crv
Old May 3, 2010 | 09:14 PM
crxb16a90's Avatar
Default need help with subframe crv
hi, i just got a crv for my wife, and went and get alignment done, becuz passenger wheel have some huge neg camber, and relize either control arm or subframe is bent, i'm not sure which, i happen have a ek subframe with power steering rack, will they intercharge? since crv use a lot of civic part? i been searching on google, nothing solid come thu. thx
Old May 3, 2010 | 10:02 PM
pkdog167's Avatar
Default Re: need help with subframe crv
The upper and lower control arm and the kunkle is most liklely bent before damage on the subframe. I beat either or both upper control arm and the kunkle are bent, possibly the frame is bent. I would check and compare suspension parts and frame from both size.
Old May 5, 2010 | 11:10 AM
crxb16a90's Avatar
Originally Posted by akitodito
ok, so if I find a 351 computer will the 302 wires work? I have bubbies with old 351 EFIs that I can pick off of. Thanks for the help.
WTF?
Old May 5, 2010 | 11:17 AM
crxb16a90's Avatar
Yea I gonna check on it, from a visual look on the body frame, I don't see any damage, like paint crack, unusual but it doesn't mean is not bent, I can't really tell, the subframe
look slightly bent, but not hundread percent sure, the control arm is the same
length on both size, and the one size have the worst camber, knockle look brand new so is the axle, posible wrong knockle? I just don't know much about crv. I sure is almost the same as civic. And the question come down to, if the subframe is bent, will ek civic subframe bolt on? Cuz I happen to have a power steering rack.
Jaydeep
Honda Civic (2001 - 2005)
Aug 8, 2010 08:30 PM
Dave_Dc2
May 13, 2008 03:56 PM
jadugartir
Jan 6, 2008 12:16 PM
srswarts3
May 9, 2006 02:30 PM
RockDawg_GSR
Nov 30, 2002 05:28 PM
