location for the transmition fluid?
Old May 3, 2010 | 06:59 PM
!!miguel!!'s Avatar
Default location for the transmition fluid?
look i sereched and could not find it!
i read that you can use motor oil and stuff like that but could not find excatly WHERE to poor the motor into the transmision nor how to take out the old fluid...
so if someone could help me on how to take the old one out and poor some new one in there because ive has my car for about 2 years and never change or even seen if it had any fluid at all
Old May 3, 2010 | 07:15 PM
blasterman87's Avatar
Default Re: location for the transmition fluid?
the fill/drain holes are on the transmission above the axle, you need to pull the pass wheel off to get to it. they use a 3/8 ratchet to take them out i believe on d series.
Old May 4, 2010 | 03:53 AM
beansandrice's Avatar
There is a bolt on the bottom by the passenger side axle that looks like your ratchet fits inside of. This is your drain bolt.
There is a goldish 17mm bolt above this bolt and this is the fill.
I choose to remove the VSS and fill from there. I use 2 quarts of syncromesh.
Old May 4, 2010 | 08:37 AM
BoombasticSloth's Avatar
pic taken from 88DXCRX from the following thread so thanks should be given to him.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-how-change-tranny-fluid-1325930/
Old May 4, 2010 | 08:41 AM
KINGVEM^^ED6's Avatar
it helps alot if you buy that beer bong looking thing they sell at like autozone to fill back up
Old May 4, 2010 | 10:56 PM
Lennart89's Avatar
yup..i used a clear hose (about 3 feet=$1.50 and connected it to the tip of the funnel)..makes your life easier..lol
bad 91 teg
Feb 1, 2011 04:09 PM
ocdcivic
Dec 11, 2004 10:11 AM
turbotime
11
Jun 25, 2004 08:22 AM
89DXDann
May 24, 2004 12:47 AM
Too_Funny
Nov 8, 2002 03:34 PM
