answer yes: front drivers side mount worthless
Ok not the mount up top, the little part that connects to the bottom of the frame where the windsheild resevoir is. Isn't this just for vibration?
I broke the stock one dropping the motor out and don't want to have to get another one.
NO.
You need that mount to keep your motor parallel with the ground.
Or run your car hard without it and tell us what happens.
NO.
This is because the EG+ never came with the front crossmember mount ? Does this mean that HASport and all those other EF B series mount makers arent doing the right thing by eliminating the 4rth mount ? Or is the issue remedied by the stronger mounts ?
lol...i saw all these guys down from alabama with all their swaps in like four cars and none had this bracket, needless to say, every car had the same dent under their hoods and same part of their valve covers chipping....hmmmmmm....
A long time ago, Jason 'Katman' Kaplan went racing and did not have that mount. His upper motor mount broke somehow and the motor moved enough to destroy the driveshaft. He vowed to put that lower mount in from then on.
See now this is waht I'm saying. Most b16 swaps into crx's do not have the front mount or that a/c mount. Just the three mounts and everything is fine. I don't care about dents in my hood or paint coming off my valve cover.
i only have 3 mounts in my b16a eg, i'm using all place racing polyurethane bushings in all the mounts. the motor sits intact and its so stiff the the vibration of the motor is transfered to the car itself. kinda anoying but i got use to it. peace
a friend of mine bought his car and it had the dents, and i knew the guy who owned it before him. the guy who had owned it before had the swap done and he showed it to me and i asked, where is the mount, and he told me that the guys who put it in said "you dont need that mount man!" he had some nice dents in his hood too. and you may not care about the dents in the hood or the valve cover, but you should care about your other mounts, tranny, clutch and all the other things that can break with the motor moving that much.
So yes, you should use the mount. If you broke the rubber piece its not too hard to replace from a junk yard.
Mike
s
Those torque mounts are very cheap and they arent that hard to find. Think sometimes man...why go through the headache of breaking things. I hope your car isn't force inducted or you in for some BIG problems.
