Best way to replace a door lock?
Ok so I have an EJ1, and someone tried to steal it from the guy I bought it from a few months before I owned it. Apparently they tried by knocking the door-lock cylinder out (the part that the key goes into to unlock it) and it's no longer there, just a hole. I searched for a while on this now and I can't really find a straight answer.
I know I'm not the only person to ever have this problem, so for those of you that have had to deal with this what's the best way to fix it? Will it involve having a separate key just for that door that's different than all the other locks on the car?
You could either go to pick n pull and have the key people there mess around with some locks to match it with your key or you can buy new locks and take it apart and match it with your key. There's some diys online.
Are there any other ways?
I'd like to avoid having to carry around an extra key just for the driver's door lock if I can.
Not to sound unappreciative of the previous advice, I do appreciate the replies so far but does anyone else have any suggestions that don't involve carrying an extra key?
Locksmith is the only way to go unless you want to change all your locks.
It is not hard to change the locks including the ignition and you could probably pick up a set for not much more than you would spend going the other way.
I was in the same boat, my trunk lock didnt match the rest of my locks. I got an extra lock from a junk yard and re-pinned the locks, its really easy.
this helped me a lot:
http://www.teamsolcal.com/forum/view...hp?f=33&t=8143
when i baught my integra it had a different key for the ignition. i got used to it, then i swapped doors cause one was dammaged, the lock is easy enough to install, as long as the peice that the lockring holds onto isnt dammaged.
gezulu
Honda Civic (2001 - 2005)
Sep 13, 2008 04:02 PM
amej8
Apr 3, 2007 10:59 AM
