mini me swap problems. help anyone?
hey guys i have a zc block and i was putting a z6 head on it. its all back together correctly but when we go to start it it just whines and doesnt crank over. could it be sensors or timing or what else could it be? your help would be highly appreciated. thanks
alright so im guessing it was flooded cause it starts but when it starts it makes an awkward noise and im guessing its the unburnt fuel coming out of the exhaust cause it stopped now but its still making the noise, any ideas?
k waht keep a vehicle from staring is no power. plugs plug wires. dizzy is set wrong and timing is off. double check all of those. as far as flooding. i have never seen a fuel injected vehicle get flooded. carbs yes but not injected. but hell what do i know. try to describe the noise better
it could be timing, the dizzy should be hooked up right. but we had to retime the crank and cam. it shouldnt be too far off if it started though. maybne a tooth or two? but could it be fuel related cause i found this weird line that doesnt hook very well i think its the fuel return line. it leaks fuel but still if thats criss crossed with something that could be it as well too correct?
i have 2000 civic ,did a mini-me swap the block is 2000 and the head is 94 , t3 turbo plus has a 440 cc injectors and 240 walbro fuel pump and msd , the computer was po6 now is p28 , it has a chip . the problem im having is the oil smells like fuel and its too black.
pretty much im afraid to start it ha. i dont want it to start on fire. its a clean shell and everything it was just non vtech dx d15b7 which is slow as **** but when i took the head off i realized i had a zc block so its a zc block with a z6 head. would that really matter?
sr20paisa
15
Feb 20, 2017 08:16 PM
CafFiend_EG6
Sep 3, 2009 03:27 PM
ek99gsr
14
Dec 25, 2005 12:42 AM
flat-blk-HB
10
Aug 7, 2003 05:44 PM
