crx dash swap
i just got a crx dash dirt cheap and i wanted to if anyone can help with a couple of questions.
1. Does the dash fit a 90 civic dx?
2.Do crx door panels fit my 90 dx?
3. Do any other interior panels,seat belts and etc fit my dx?
4. Does the crx cluster plug rite in to my harness if not what can i do?
I heard you have to cut a bit of it or something for the back part to sit right. Just put it in and you'll probably see. Plus the CRX dash looks way better!!!
Door panels are the same except that the CRX Si one's say CRX on them.
The seatbelts I think are the same also. The door mounted ones.
and I THINK that the wiring is the same.
yes dash and door panels will fit, but i think as long as they are from a 90-91 crx not a 88-89. i beleive they are different but not 100% sure.
I got CRX door panels in my 91 std now. Id live to recover them so i dont always have ppl ask why they say crx lol
not sure about #3 or #4.
If you have a tech on the crx cluster then ima say no go on plug and play. but once again not 100%
I had to re-pin one plug that was different. It wasn't a difference in years either, as the donor dash was a 91hf and my car was a 91std. Could be the hf to std factor. If you get a dash with the harness, just compare all the connectors. Also be sure to get the bottom bracket that mounts the dash to the center floor.
P()()RB@Y
Dec 21, 2002 05:52 PM
