....Brake Light Stays On....
Old May 2, 2010 | 06:03 PM
I8Stang's Avatar
Default ....Brake Light Stays On....
Recently did a swap in a 92-95 Civic hatch.. after hooking up the battery, just the 2 outer brake lights remain on all the time. So when I apply the brakes, nothing changes.
Thoughts / ideas?
TIA.
Old May 2, 2010 | 06:14 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: ....Brake Light Stays On....
Possibly coincidence?
Look at #23 in this diagram:
It is a small plastic insert that pushes against the button on your brake light switch. Over time the plastic crumbles and it falls out, making the brake light switch stay open all the time, which keeps the brake lights on.
Look under your dash where the brake light switch button itself goes through the hole in the brake pedal, and see if the plastic insert is still in the hole in the pedal assembly. Also look for crumbled plastic (usually original ones are blue; replacements are white) in the floorboard area too. That'll be the smoking gun for a busted brake light switch grommet.
If this is your problem then it had nothing to do with your swap.
If your plastic piece is still intact then I'm at a loss. you might have a poor ground/missing ground somewhere in the engine compartment.
frustrated1965
Aug 18, 2024 10:00 AM
eTiLiKo
Aug 9, 2018 03:03 PM
Hardrock1l
Honda Civic (2001 - 2005)
Apr 25, 2017 08:20 PM
91b18a1ls
Mar 19, 2011 10:24 PM
cyclonedr
Oct 7, 2009 01:47 PM
