Temp gauge repair for d15b1. Newbie to Civics first challenge
Old May 2, 2010 | 02:40 PM
EQ6ESM's Avatar
Default Temp gauge repair for d15b1. Newbie to Civics first challenge
To all the Honda Gurus out there that are giving of their Wisdom when I ask for help, a grateful thanks you to all of you.
I have purchased a 1991 Civic with a D1b51 engine and a four speed transmission. This has turned out to be a good running car even though it burns a bit of oil and has 350,000 K's on it.
The body is straight and does not have any rust holes at all.
At this time she is a commuter, later she will be turned into a very nice rebuild and up grade as my experience grows with Honda's.
What I am trying to do now is get the bugs out of her. The Temp gauge on the dash does not function. I have replaced the radiator, next is the thermostat and the temperature sending unit.
What is the easiest way to remove and re-install the sending unit, when it is beside the oil filter, under the fuel system in the back of the engine?
When I put the new rad in the car, I used the larger size. Will the fan motor and fan diameter used on the smaller rad be enough for the larger cooling surface?
Thanks Again for the information.
EQ
shkspr1048
Honda Civic (2001 - 2005)
Mar 25, 2016 02:20 PM
phoenix230197
Jul 12, 2010 12:14 AM
huepowered
May 13, 2006 05:53 AM
si 1
Dec 31, 2005 07:44 PM
brandond
Nov 6, 2005 02:59 PM
