question about wheel spacers and can i get pictures? please
at the moment i have +38 offset.. i wanna buy spacers to give it a kind of a flush look..
1st question; do i need anything special (bolts, extended lugs)?
2nd question; does it matter what brand i get?
3rd question; whats the size spacer i need to give me that flush look?
4th question; does anyone even run with spacers on a daily?
5th question; can someone post pictures of cars with spacers on.
thanks.. this is gonna help me if someone will answer these question.. bump to help me out !
I have an EJ sedan with 15x7 +40 on it. Im using Ichiba 15mm bolt on spacer all around and its pretty "flush". Feels more stable in corners, turning radius is worse, spring rates are slightly softer. Just measure the distance between your tire and the fender lip. You can roll or pull the fenders if you need to.
pics
pics
pics
pics
for spacers anything over 5mm will need extended lugs because after that the lug will not safely screw on enough turns. or some spaces come with studs attached, just depends what your looking to do, and there is no prob running them daily that i know of...
does anyone have a +38 offset with 10mm spacers?
Stickied at the top of this forum is a topic:
Forum Rules and FAQ - READ BEFORE POSTING
It says:
It says:
Originally Posted by Forum Rules and FAQ - READ BEFORE POSTING
Rules
7. Bump once and if you still don't get the info you're looking for just let it die, don't bump it again. If you bump the topic a second time, the topic will be locked and you will lose points. Think about this - this means that if you use your single bump on your topic after an hour, when it's still at or near the top of the forum topic list anyway, it will be wasted when it doesn't accomplish anything for you.
siregcivic
Feb 12, 2006 09:00 PM
