ek to ef suspension
Old May 1, 2010 | 07:15 PM
91lsteg's Avatar
Default ek to ef suspension
i have a full suspension on my ek coupe.
sk2 pro type coilovers
sk2 lca
sk2 camber kit front and rear
asr sub frame brace
sway bar w endlinks
will any of this mount onto an ef hatchback????
or heck a eg sedan
Old May 1, 2010 | 07:58 PM
jdm36's Avatar
Default Re: ek to ef suspension
not really sure about the ek suspension,but i have eg suspension in the front of my ef hatch,i have the shocks and forks,if that helps.
Old May 1, 2010 | 08:01 PM
rustanghunter's Avatar
im pretty sure ef-eg-ek are all interchangable with minor differences, but im no expert
Old May 1, 2010 | 08:15 PM
90_EX_Civic's Avatar
sk2 lca
asr sub frame brace
sway bar w endlinks
or heck a eg sedan
every thing except for that. think the brace is different for the ek. oh, and u will be sitting about an inch higher.
Old May 2, 2010 | 04:56 AM
91lsteg's Avatar
ok heres what im doing.
all the ek suspension is going on a ef.
the eg suspension is going on the ek.
the ef suspension is going on a eg
Old May 2, 2010 | 06:58 AM
EFRue57's Avatar
wrong, front camber kit is different, end links are different, lower control arms are different, and the subframe piece is different. the coil overs can be used but weren't really designed for the car.
and to the OP, here's an idea, why not use eg suspension on an eg, ek suspension on an ek, and ef suspension on an ef? I know, I know, seems a strange concept using parts that were made for the car, but you never know, it might work.
Old May 2, 2010 | 01:50 PM
91lsteg's Avatar
yeah i agree.
thats y i have ek stuff on ek. eg on eg....
but if im geting rid of ek why not try and swap out the beter ek parts on2 the eg.
so nothing from the ek will fit the eg. - the coilovers??????
Old May 2, 2010 | 02:16 PM
EFRue57's Avatar
from the ek to eg, most everything will swap over. the coilovers will work, you just need to swap out the drop forks and make sure you use the eg forks on the eg and the ek forks on the ek. also the front and rear camber kit should be direct bolt on, as well as the lower control arms. rear subframe will not be a bolt on though and i believe the end links are different.
Old May 2, 2010 | 06:12 PM
91lsteg's Avatar
ok thanks alot sir.
what about the rear sway bar. it should work correct?
Charlie Moua
64
Sep 19, 2009 04:37 PM
rjones
Suspension & Brakes
Mar 4, 2008 02:16 PM
hellogoodbye
Jan 17, 2006 03:06 PM
spock_rocker
11
Aug 13, 2003 05:23 PM
Todd00
May 9, 2002 04:13 PM
