Help. Need J35 vs. J37
Old May 1, 2010 | 04:03 PM
rdavid1065's Avatar
Default Help. Need J35 vs. J37
I need a Honda engine genius. I am building an airplane that currently uses the J35 (pilot J35a4) an an engine choice. I would like to use the J37, but need to verify a few hard to find pieces of information. Could someone please throw me a bone? Here is what I need to know:
Does the J37 have the same engine mount dimensions as the J35? i.e. could you drop in a J37 into a J35 "hole" and have the motor mounts line up? The engine mount assembly for my airplane is made for a J35, and the J37 needs to line up and bolt in the same place. Size doesn't matter here, so it doesn't matter if you can't make a J37 fit into the Pilot's engine compartment, only thing that matters is would it line up with the mounts.
Is the J37 single port exhaust? I think I found that it was, but need to be sure.
What is the dry weight of the J37 and J35?
I hate to hijack an automotive site to ask these questions, but I can't seem to find it anywhere. Thanks a ton in advance, I really appreciate it.
R
Old May 4, 2010 | 06:03 PM
splatV6's Avatar
Default Re: Help. Need J35 vs. J37
You might find out more on J32a.com.
Old May 6, 2010 | 07:48 AM
rdavid1065's Avatar
Thanks Splat. Looks like a good site to ask this question.
Old May 6, 2010 | 07:55 AM
kyden's Avatar
j37 has the single exhaust port. that is all i know.
Old May 10, 2010 | 06:40 AM
rdavid1065's Avatar
Thank you Kyden. Any and all info is useful.
Old May 10, 2010 | 08:55 AM
pasaunde's Avatar
K20a.org also has a J series thread, probably alot of the same guys that run in J32a.com.
My brother runs a Type S (J series) swapped hatch, on a stock ECU it put down 260Hp & 220 Tq SAE. The J32 Type S motor might be a tad lighter, and more power than the Pilot motor.
JayDaTroll1
Aug 22, 2018 10:56 PM
greyEG
Jul 20, 2014 07:05 PM
smd6942
Aug 12, 2010 09:59 PM
marc-111
Jan 25, 2006 11:37 PM
hardware17
May 23, 2002 08:50 AM
