CA 94 honda civic hatch h22 swap
NO TRADES
Cant finish my project, got laid off and got bills to pay trow me an offer, no low ballers, reg is past due so ill be around $250
94 civic hatch dx with h22 swap
salvage title
runs and drives needs to be registered and smogged probably ref'd
will probably pass ref only thing needs to be wired up is egr sensor
running on usdm p13
no check engine light on
no AC no PS
Body
white color
key-less entry
99-00 si front end
99-00 si fog lights
Interior
92-96 prelude front seats
rear seats from integra
cargo cover
pre-wired for amp
pionner cd player
Motor
h22a1 usdm with 134.xxx
DC headers modified to fit hatch
2.25 exhaust i think with cat converter
slim fan
ngk spark wires with ngk spark plugs
everything was changed except headgasket
new honda water pump
new honda timing belt
new honda oil pump
new honda gaskets
new honda oil rings
new honda oil pan gasket
Tranny
fidanza 8lb flywheel
ACT stage 3 pressure plate with Exedy stage 2 clutch
forbidden short shifter
2nd thru 4th gear was replaced
new honda oil
new honda gaskets
Suspension
gsr blades with falken tires
H&R full adj suspension with polyurethane top bushings
Omni power front camber kit
front and rear civic si sway bars
rear disk brake conversion from civic si
new inner tie rods
Extras
Skunk2 stage 2 cams with adj cam gears
extra h22 dc headers
might have some other stuff cant think of any at this moment
Bad: reg/smog when turning right vibrates idk why
salvage title
running on usdm p13
no AC no PS
Body
white color
key-less entry
99-00 si front end
99-00 si fog lights
Interior
cargo cover
pre-wired for amp
pionner cd player
Motor
slim fan
new honda oil pump
new honda gaskets
new honda oil rings
Tranny
new honda oil
new honda gaskets
Suspension
new inner tie rods
Extras
97jrscgsr
Feb 2, 2003 10:46 PM
