FWD Radial: IFO Baton Rouge
There will need to be at least four confirmed entries to seal the deal. If you are interested in competing in this class, it would best that you inform the IFO main office or agent so that event plans can be made early instead of last minute. This class isn't for the faint of heart. This class requires skill, patience, and perfection.
Here are the rules:
FWD RADIAL
This category is reserved for heads-up 1/4-mile racing that integrates a large creativity base for FWD-only combinations. It brings on a new level of competitive diversity. In the end, it’s the first to the finish line that wins.
SPECIFIC REGULATIONS:
Turbo/Supercharged cars:
• Single turbo of any size or configuration; or one supercharger of any size or configuration.
• 4 cylinder engine only.
• Intercooler must be located in front end and/or under-hood location. Mounting intercooler in the cabin or rear of car is prohibited.
• Nitrous prohibited
All-motor/Nitrous cars:
• Nitrous oxide permitted if not "force inducted."
• 4, 5, or 6 cylinder engines only.
GENERAL REGULATIONS:
Engine:
• Any 4, 5, or 6 cylinder engine (depending upon method of aspiration used) of any size or configuration as long as it was originally produced for FWD.
• Engine may be from different make as car used.
• Transmission may be from different make as car and/or engine used.
• Adapter plates permitted (structural integrity is considered during inspection).
• Any induction type or style permitted as long as it is of automobile design.
Drivetrain:
• Front-wheel drive cars only. Must have been originally produced with a front-wheel drive only configuration. Converted AWD cars are prohibited.
• Gear boxes for driveline other than transmission are prohibited.
Chassis:
• Wheelie bars prohibited.
• Full tube chassis cars are prohibited. Must have full original floorboard.
Suspension:
• 4-link or fully fabricated suspensions are prohibited. Traction bars are allowed.
• Live or straight rear axle prohibited.
Tires:
• Tires are limited to treaded tires or treaded drag radials only. DOT slotted drag slicks or cheater slicks are prohibited. Profile may not exceed a P225, and the sidewall is limited to a maximum of 60R. Wheel may not exceed 15" diameter.
Body:
• The following are prohibited: Lexan and riveted windows.
• Bumpers can be cut for intercooler, vents, etc
• Must have corner lenses and/or light assemblies installed.
• Hood may be notched or cuts to gain clearance for engine.
Interior:
• Two fully upholstered seats are required.
• Rear seat may be removed.
• Complete dash removal is prohibited.
• Must have driver and passenger door panels.
• Carpet, Radio, A/C are Optional
Fuel:
• Nitromethane, methanol, propylene oxide, toluene, and diesel are prohibited. High octane race fuel or pump gasoline only.
Here are the rules:
FWD RADIAL
Engine:
Drivetrain:
Chassis:
Suspension:
Tires:
Body:
Interior:
Fuel:
streetimports
Jul 22, 2004 01:20 PM
