Rear engine mount question
Old May 1, 2010 | 01:46 PM
BoombasticSloth's Avatar
Default Rear engine mount question
I am replacing my rear engine mount on my 90 crx si with new oem honda mounts. It is a stock engine. There are three holes on the mount that appear to bolt down to the rear cross member. Below is a top view of the mount.
I can see 2 bolts and will likely be able to access them through swivel joints and extensions, but I can't seem to see the bolt head for the rear middle hole, (red arrow) as there is no room to access it. Is that hole just for a centering pin or centering nub or is a bolt suppose to go through that hole?
I looked at the helms manual and it doesn't show a bolt going through that hole. I am stumped.
Thanks for any assistance.
Old May 1, 2010 | 03:25 PM
bradennicely's Avatar
Default Re: Rear engine mount question
i think you can reach it from under the car with a 17 wrench not for sure on the efs
if anything you can lower the rack down and get it
Old May 1, 2010 | 04:40 PM
D16SiHatch's Avatar
there's definitely a bolt there.. and i remember it being a huge pain in the dick trying to get to it lol
Old May 1, 2010 | 07:25 PM
I figured there had to be bolt there to better secure the mount to the rear cross member given the torque that the mount will be exposed to. It's just I couldn't access it at from above nor below the car - out of sight and out of reach. I can't even get a finger in that area, above and below. I figured the only way was to drop the rear cross member which I am not really too thrilled about doing. .
Old May 1, 2010 | 07:46 PM
ryanevansoh's Avatar
just lower the rear crossmember a little and its easy to get to. much better than banging up your hands trying to squeeze in that tiny spot to get it
Old May 1, 2010 | 11:39 PM
D16SiHatch's Avatar
i can't recall what i used to get to it but i do remember doing so with the engine still in the car and without dropping the cross member. i know that doesn't help much lol.. but it can be done
Old May 2, 2010 | 12:40 AM
it can be done but its easier on your hands to just lower the crossmember a bit
Old May 2, 2010 | 02:15 AM
ClassicTuners's Avatar
i'd lower the x-member, it's only 4 bolts for the x-member and 1 bolt at the bottom of your steering columm
nicob
Honda CR-V & Element
Feb 27, 2019 01:09 PM
Mr.Meowsome
Dec 1, 2006 11:27 AM
b16a2EBP
Mar 23, 2006 08:40 AM
getnasty
35
Jun 15, 2005 02:50 PM
ragejed
Jul 10, 2002 04:30 PM
