What's the Best Way to Clean the top of the pistion
Old Apr 30, 2010 | 05:39 PM
98Accord250K's Avatar
Default What's the Best Way to Clean the top of the pistion
I just pulled the head off of my Accord and the tops of the pistons are covered with carbon (what do you expect after 250K miles??!!) What's the best way to clean the carbon off the pistons while they're still in the block?
Thanks.
Old Apr 30, 2010 | 05:46 PM
GhostAccord's Avatar
Default Re: What's the Best Way to Clean the top of the pistion
Spray them down with carb cleaner/throttle body cleaner. Let them soak for a while, keep spraying if neccessary. Then rotate the crank shaft until the number one piston is at TDC. It will be out of the cylinder hole .002" and that will allow you to use s nylon brush to scrub them clean. Rotate the crank for each piston and do the same.
*Note, drain the oil and leave the drain bolt out of the block to allow any cleaner that gets past the rings to drip out. Allow the block time for the cleaner to evaporate before adding oil. How long all depends on how much cleaner you spray in the block.
Old Apr 30, 2010 | 09:13 PM
Thanks, GA. I'll give it a try.
Old Apr 30, 2010 | 10:27 PM
nus_dogg's Avatar
Good info, I'mma be pulling my head in a few weeks here, so I might need to do this if they're carbed up.
Old May 1, 2010 | 05:27 AM
Note*, You should also ensure that you wipe each cylinder wall down with a generous coating of oil when you are finished cleaning the piston. You don't want to leave the cylinders washed & dry. To do this you rotate the crank to BDC (piston is all the way to the bottom) and then take a clean lint free cloth, add a generous amount of clean engine oil, and wipe the cylinder wall down. Make sure that you coat the entire cylinder surface.
Old May 1, 2010 | 05:33 AM
DLO01's Avatar
Leave it there. More compression.
Old May 2, 2010 | 12:40 PM
Atomic1's Avatar
Marvel Mystery Oil seems to be better suited for this. TB cleaner will just evaporate.
MurtazaDSM
12
Jan 31, 2012 10:26 AM
hondachris1994
Mar 7, 2008 04:34 PM
DC2 Mang
Apr 30, 2006 06:37 PM
Layziebtnh055
Jun 22, 2004 03:55 PM
