Bleeding Clutch Problem......I'm Stuck...
Okay so this is what happening:
When i bleed/pump the clutch, the pedal will go from GREEN Pedal to RED Pedal then have resistance (This is where i have been pumping to, during the bleeding)...(I can pump from Green to Red all day with no problem)......If i try Pushing the clutch Pedal from RED Pedal to BLUE Pedal, the Slave Cylinder will Leak....Then air gets back into the line again...Back to square one....
After bleeding for a while (GREEN to RED Pedal Only) the pedal still feels spongy & when i press my clutch pedal from GREEN to RED the car wont start...(If I try to press the pedal from RED to BLUE i'm sure the clutch slave cylinder will leak/**** up again...................
PRETTY MUCH I CAN'T PRESS THE CLUTCH ALL THE WAY DOWN WHEN I'M BLEEDING OR THE SLAVE WILL LEAK....
This is how I've been bleeding:
1. get someone to pump clutch pedal 5-10 times & hold pedal to the floor.
2. release slave cylinder bleed valve & re-tight it back.
3. Tell person doing the pedal pump he can let go of clutch pedal & pump again.
4. Start over with step 1 till clutch feels normal again.
This is the Hanyes Manual Instruction.......Imma try this out, but it takes a long time
1. Release Valve on Slave.
2. Have someone then press clutch pedal down & hold.
3. Tighten Slave valve back up.
4. Tell someone to bring clutch pedal back up.
5. Repeat process......
Day 3 wrking on vehicle :'(
It's a new Slave & Clutch master cylinder....& yes the clutch fork does move to. I have just try the Hanyes process above and it dont wrk for me some how......Damn think imma need to take it to the shop & see whats up...
The slave is NEW (I exchanged the 1st new Slave for another new Slave just to make sure i didn't get a Defective slave) .....If I use the 2nd Method/Correct Method, this problem doesn't a rise, but the clutch pedal doesn't stiff up like it suppose to.....Think i need to try it again tommarow......
FLCivic
Jun 30, 2004 03:48 PM
