Replacing Mitsuba starter
Old Apr 30, 2010 | 12:48 PM
BoombasticSloth's Avatar
Default Replacing Mitsuba starter
Hi all,
I am currently replacing my mitsuba starter on my 90 crx si. When I took my starter out, the part which sticks inside the engine block is covered with a brown powder. I think that part is called the overrunning clutch assembly. Is that something I should be concerned about?
edit: here is a pic of what I am talking about.
Thanks in advance for any insight you may have on the matter.
Old Apr 30, 2010 | 01:25 PM
4g4dcruisin's Avatar
Default Re: Replacing Mitsuba starter
Is the protective plate on the bottom of your tranny removed by any chance? Its held on by 3 or 4 bolts just near the oil pan. It will allow crap like water/dirt to get up in there and it looks like rust.
Old Apr 30, 2010 | 01:55 PM
No, the protective plate on the bottom of the tranny is not removed. I had the car since new and I have never removed it. It doesn't look like rust. It is just brown powder and I can wipe it off. Is that just powder from the clutch? When I look inside the hole on the engine block I see some brown powder on what appears to be the flywheel as well.
Old Apr 30, 2010 | 02:10 PM
This is the first time the starter has ever been off? If so, dont worry about it. Just replace with a new starter and go for it. If you have no metal flakes in there or any other damage, then you're fine.
Old Apr 30, 2010 | 03:10 PM
Yeah, this is the first time the starter has been off. Man the lower starter bolt was a biatch to get at. I have a feeling I am going to have even more fun torquing the bolt back on.
thanks mate.
alowe336
Honda Civic (2001 - 2005)
Apr 7, 2017 06:40 AM
alowe336
Apr 3, 2017 08:39 PM
serg92hatch
Aug 27, 2010 03:50 PM
daidilus
Jul 26, 2004 06:27 AM
B19CivicHB
Dec 26, 2001 09:01 PM
