B18B crx will not start???
Old Apr 30, 2010 | 10:40 AM
91SIR's Avatar
Icon6 B18B crx will not start???
Ok i got a 91 crx si with 96 ls motor went obd0 dizzy, injectors and pr4 i have spark and fuel. well fuel after i jump the main relay, sodering tomorrow. checked all the grounds they are good the only thing not hooked up is the temp sensor and o2 but they shouldnt keep it from starting. i would think. ive exhausted my knowledge so im turning here. anything else i should check???
Old Apr 30, 2010 | 11:58 AM
ryanevansoh's Avatar
Default Re: B18B crx will not start???
i would get the temp sensor hooked up and then check timing
Old Apr 30, 2010 | 11:59 AM
jdmsi1991's Avatar
try ur vaccum and the idle adjustment screw
Old Apr 30, 2010 | 12:09 PM
Jockone's Avatar
Is it turning over or not?
Old May 1, 2010 | 08:08 AM
91SIR's Avatar
yeah its tuning over and has good spark. i got to thinking im gonna check the compression and see what that yeilds. no compression no start. i dont think its an idle screw issue it should start with the throttle open. its not even tring to fire off its just turning over.......
Old May 1, 2010 | 10:48 AM
91SIR's Avatar
Ok problem solved compression test yeilded every low numbers across the board like 45psi checked the cam timimg and intake cam was like 4 teeth off. i never had the belt off or even the cover for that matter. set to correct timing and fired right up
K20moesh
11
Apr 22, 2015 09:04 PM
fitbkeco
10
Mar 2, 2013 02:15 AM
pink_nightmare
Jun 28, 2010 07:29 PM
jweeks
Jul 14, 2008 04:35 PM
Lan
May 23, 2005 12:56 PM
